Question about Sharp Office Equipment & Supplies
The printout has a dirty line on it! - Sharp Office Equipment & Supplies
The printer is printing dirty pages
Posted on Mar 09, 2009
Blue lines accross my color printouts. They are on one side of paper. Hp color laser 4600dn.
YOur printer is dirty need to clean it with q tip and acohol use flashlight you will see where ink is built up
Jul 08, 2009 | Epson Aculaser C1100 Printer
Dirty printout copy
Hello sir; Just need to replace drum cleaning blade should take car this problem.
Apr 26, 2009 | Office Equipment & Supplies
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
I have a problem when printing i get lines on my photo ,s
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem.
If it is vertical line then it indicate an almost empty or faulty toner cartridge or some spilled toner inside the printer.
if you require further help feel free to ask
mention your model no
how old is your printer ?
Thanks for using Fixya
SAM ANDERSON
Sep 13, 2008 | Cannon Office Equipment & Supplies
Dirty roller ?
Actually it sounds like you need to replace the drum cartridge.
Mar 24, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Dirty printout and paper jams
Hi Hazel,
Sounds like it needs a maintenance kit. This will include a fuser, which should resolve the problem of the repeated horizontal lines and ghosted words. It will also cause more frequent paper jams when it needs maintenance.
A manual for installing a maintenance kit can be found online but sometimes will come with the kit. Google it anyway as it will give you an idea of the work involved.
Hope this helps!
Mar 12, 2008 | HP LaserJet 2200dn Printer
207 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
