Question about Garden
I am replacing the metal spring for the fly wheel. What is the best way insert the coil and recoil rope without the coil unraveling?
    Brigadier General:
  • 4,088 Answers
Take the pull cord off of the spool, then wind the spring CCW until it seems strong enough to return the cord when it is pulled out. Wedge the spool so that it doesn't unwind the spring, and work the cord into the spool. If you have to form any knots, be sure to melt the cord end so that it prevents the knot from slipping off. Hope this helps!
Posted on Sep 13, 2010
Can i take the pull starter off my briggs and stratton mower in one unit
Yes you can... if you are removing the center screw and wanna take the whole rope pulley off, do it slow... if when you start pulling off the pulley and you feel like the recoil is coming up with it, immediately put it back down or the recoil spring will unravel fast... it's not impossible to ravel the spring back up, just a pain if you have never done it before. If you are trying to install new rope, you can do so without removing the pulley at all.
Go to you tube and you will find multiple videos on how to replace rope on lawnmower recoil assy
Tons of videos. You can do this!! Good luck
Oct 11, 2015 | Garden
Can i take the the pull starter off my briggs and stratton mower without dismantlng the spring
Tons of videos. You can do this!!!!! Good luck!
Mantis tiller qiuts after a short running time ,then cant pull the recoil rope
Anon, it sounds like you need to get your Mantis serviced. If you cant pull the recoil rope it sounds like the coil is overheating and obstructing the fly wheel.
Jul 11, 2014 | Mantis 2-Cycle Tiller
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Lawn mover starter rope replacement
most starters can be taken off the engine and replace the rope without completely tearing the whole unit apart. by that I mean you should not have to mess with the recoil spring unless it is broken. remove old rope from pulley, wind up the pulley and hold it so it wont unwind, replace new rope onto pulley and tie a good knot and melt the ends of the rope so it wont unravel, then slowly let the pulley retract the correct amount of rope. if the recoil spring has unsprung on you, it will take a little time and probably several tries to wind it back up and position it back in the starter. they like to unspring while doing this so take some time and an extra person to hold and assist might go a long ways. good luck. R
Aug 25, 2012 | Ariens 21 In Classic Walk Behind Push Lawn...
How do I install a recoil spring ?
Sometimes the hook at the end of the starter spring has broken off from rust or has straightened itself out. What I do if I don't have time to get a new spring is make myself a hook and attach it to the notch. Then you have to manually wind the spring in the right direction and hope that the spring doesn't unravel on you. Wear safety goggles for that!
If I need to get it started without the recoil spring, I just wrap the starting rope around the engine and start it that way until I have time to get a new part.
Jun 14, 2017 | Briggs & Stratton Garden
How do i get the spring back into the recoil
I think he's trying to replace the recoil starter spring. He's having trouble getting the spring and pully and rope back into the housing. I'm trying to do the same thing with an old Green Machine weedeater and would appreciate any help.
May 10, 2010 | Craftsman 25cc Gas Line Trimmer
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Oct 22, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
