Question about GE Profile PGB916SS Stainless Steel Gas Kitchen Range
Pgb916sem1ss ge profile gas range. the center burner only partially ignites. i have to use a match to get it to light completley all the way around. what could the problem be?
  • asteve Sep 13, 2010
    Thanks, for your response. I will follow the steps you suggest. however, the burner works every time; it never doesn't ignite. the problem is that only half of the ring ignites; in order for the rest of the ring to ignite, i need to touch a flame to the burner orfices. Will your suggestion cover this issue?
    Also, i have a gas range, as mentioned in the problem, this sounds like a solution for an electric range, doesn't it?
    Genius:
  • 1,478 Answers
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
Posted on Sep 13, 2010
  • Jimoh Adeleke Muyideen Sep 13, 2010
    As i said earlier, you will need to clean your burner assembly and igniter, Lift the burner assembly off the support arm as you slide it away from
    the burner valve port. It just rests there. Remove the shipping screws
    if they're still in place. clean all the necessary parts because they may be clog with dirt not allowing the pilot to ignite.
The left front burner of my GE pROFILE 30'' GAS RANGE DOES NOT LIGHT ,ON ONE OCCASION A FLAME SHOT OUT FROM UNDER THE BOURNER. OTHER WISE IT JUST CLICKS AND DOES NOT LIGHT
Does it light with a match?
If it does not you need to have a profesional check you burner injet. It may be clogged up. Try cleaning your burner base and burner parts. Sometimes they get full of food gunk.
If it lights with a match then you can try changing the igniter switch that is on top of the gas valve.
Good luck
Sep 23, 2013 | Kitchen Ranges
Rgb532bew2wh oven low heat
regulater thermo fault dont mess with it it is gas dont take risks get qualified engineer life is worth more tham money
CAUTION DONT TAKE RISKS ITS YOUR FAMILY CAUTION
Aug 17, 2012 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE XL44 range - electric igniter for top burners not working.
Sounds like igniter problem. Did some one pull the electrical cord or has a fuse or breaker blown/ Things to check. Your igniter is run by electricity.
Dec 30, 2017 | GE Profile JGP636 Gas Cooktop
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top burner Spectra XL4
rear left back burner clicks to ignite but doesnt
Feb 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra Range/Oven XL44
Resettle the small center tops on the burners. If even one is slightly off center or not level, a burner will not light, although it will click. Cost me a service call to learn this!
Aug 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile PGB916SS Stainless Steel Gas Kitchen Range Logo
113 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
