I am trying to contact tthekraut. I am looking for a Panasonic DVD drive #VXY 2010 for a Panasonic dmr-ez485vk vcr/dvd combo recorder. I noticed on a recent post he offered to help the poster to locate a replacement drive. I can't seem to find one at a reasonable price. The places I have found priced the drive at $135.00 to $250.00!!
SOURCE: Instructions for Programming Innovage Jumbo Universal Remote
YOU CAN DOWNLOAD THE DOCUMENTATION FOR THE INNOVAGE REMOTE HERE:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
JACK D
Posted on Feb 12, 2008
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
SOURCE: WHEN I TRY TO USE
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Posted on Jan 08, 2009
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Posted on Jul 25, 2009
vinzen
  • 217 Answers
SOURCE: i have a panasonic dmr-xw450
Are you sure this records directly to DVD discs?. I did a search and could not find conformation of that does your owner's book confirm it? I know this is a top of the line DVR but confirm it.I did see plenty on the complicated Remote the answer may be with it.Good Luck.
Posted on Sep 10, 2009
No sound when I play back a commercial DVD
May be something wrong with HDMi cable.
Is there sound when play VCR?
Please test - check with regular RCA cable AV out.
If OK. Next step Replace HDMI cable.
IF No sound with RCA cable look like need replace VCR Main Board.
Feb 20, 2015 | Panasonic DMR-EZ485VK DVD Recorder/VCR
When I try to record a dvd with timer or manuel it will not record, says err
Solution:
1. Not good DVDRW media blank
2. Open Panasonic model support page, click download software, Update Firmware
Dec 16, 2014 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have panasonic dmr-ez485v dvd recorder cambo, it has F60 code don't turn on or off
Hit reset button, unplug it or swear at it. If you looked up online find more problems listed on unit then ways to correct problems. Does have nice play back. I bought a DVD maintenance kit seams to help some issues. good luvk
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have DMEZ 47V DVD recorder/VCR combo and panasonic digital/ HD tv...when I set up to pre record the equipment seems to accept the information ok but when i try to playback all i get is ..."cannot...
The reason for this is simple; the built-in digital tuner does not support HD, only SD. You cannot fix it, at least not economically where the recorder combo is concerned. But you can obtain a separate HD set top box, and connect the outputs of it to the inputs of your combo if you really want to record HD channels. It's crude, but cheaper and easier in the long term, and it doesn't damage your machine.
Feb 17, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd no read error
The 'NoRead' error points to a faulty DVD-RAM drive. If the drive is making clunking/whirring noises, and taking too long to read an inserted disc, chances are the traverse unit (spindle motor/laser assembly) within the drive has failed. Unfortunately, this part cannot be replaced; you would need to replace the whole drive.
Look around for a good cheap used one, or, if you are prepared to do so, order a new drive (brand new DVD-RAM drives ordered through Panasonic could cost a couple of hundred dollars or more though so be warned). Check the model number on the top of the drive (prefixed with VXY before considering any replacement.
Feb 12, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Need to turn on DVD/VCR unit inorder to view the TV.
Hi there, You shouldn't have to turn on the DVD to view the TV only. But if you have it in AV1 mode or DVD then you will, coz it's trying to operate thru the DVD unit. Hope this helps, tho it's been a while since you asked?
Jul 14, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Need PANASONIC DMR-EZ485V remote control codes for vizio VA220E. Have tried 0178 and it works the on/off but what will also work the channel and volume? Thanks for any help. Fran
I connected my Panasonic DMR EZ485V DVD Recorder in 240 VA, and after to broke (burned) the safety fuse. Do you know what is the value of the fuse??? I need replace this, but I don´t know the specification. I know my Panasonic DMR EZ485V DVD Recorder work 120 VA. Best regard
Jun 29, 2009 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
