Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Gas range top igniton not clicking, gas come on when lit with a match
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Sep 14, 2010
2 burners on Kenmore gas range will not ignite. Ignitor clicks, then clock beeps and blinks
Good afternoon. It is more than likely that the little spark that comes from that clicking noise is not sparking. Here's a quick fix take a match or a lighter turn you're not on to where it clicks with a lit match it will light if your gas is coming out it will light. Leave it on just for about 30 seconds do it to both of your burners this should solve the problem. Usually after I wash my stove top off is when one or two of mine have done this to me . if it continues to happen however take a small piece of steel wool around that little ignitor tip ( they gather soot and grease at times) and just go across that for a few seconds each. Good luck I hope it helps I know it does on mine.
Nov 06, 2016 | Kenmore Kitchen Ranges
Oven will not heat, control panel is eratic, gas burners will not spark
Check fuse box to see if stove is receiving power. Turn one top burn on and hold a lit match to it. if it does not light. Call gas company to see why there is no gas to your stove.
May 15, 2016 | Kitchen Ranges
Amana gas range top. Burners click but see no spark and won't light
Make sure the gas is on or connected or just call a repair man
Sep 19, 2015 | Amana Kitchen Ranges
Pilot lights will not stay lit on stove top or oven. Can light burners with match. Crosley c3100paw
You need to clean thermocoupling off it what the pilot lit uses to stay lit. you canuse sand paper or brush May need to replace, clean gas tubes on pilot also could be that
Dec 12, 2011 | Crosley Kitchen Ranges
How do i re ignite the pilot light
Hi
The surface on this range have standing pilots that must be lit initially. To light them:
1. Be sure the surface burner control knobs are in the "OFF" position.
2. Remove the grates and cook top.
3. Locate the pilot ports and light each of them with a match. Replace the cook top and grates.
Light the oven burner pilot in the following manner:
1. Be sure the oven control knob is in the "OFF" position.
2. Remove the broiler carriage.
3. Hold a lighted match at the top forward section of the pilot (See diagram). No adjustment is required.
4. Replace the broiler carriage.
Hope this helps...
Daniel
Aug 28, 2010 | Magic Chef 31000 Gas Kitchen Range
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Problems with Brown Stove Works TM110-3 Gas Kitchen Range
http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
there you go, the complete manual to operate your stove. look on page 16 to read about the pilot in the oven and how to proceed.
May 20, 2009 | Brown Stove Works TM110-3 Gas Kitchen...
My admiral stove stopped working, the elements just arent on anymore, but the stove has power because i plug my toaster into the socket on the stove and it still works, and everything else in the kitchen...
first thing is to check you r circuit breaker,is it an electric range ??? or a gas stove with electronic iginiton???, if its a full electric range then youll have a double breaker powering your unit, and its possible that one of the breakers tripped, allowing only half power to the unit.if its a gas with electronic igniton then slightly different matter and then i would ask of the top elemnts will light with match and perhaps theres an issue with the electronic spark switch
Oct 22, 2008 | Kitchen Ranges
Oven and broiler will not light.
You've probably done this by now since your message is May (makes us a May-December couple??) but wanted to write that the transformer that produces the park for ignition has failed.  I don't know how accessible it is in your unit, if you check on Sears website under Parts with your model # in hand, they could well have an illustrated breakdown of your range which would give you an idea of how difficult the replacement might be.
May 10, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
221 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
