Question about Dell Dimension C521 PC Desktop
Audio format trying to use my mic for the first time when in yahoo messenger it says pc does not have the right audio format for me to use my mic i have a new pc its a dell dimension c521 and it s runing on vista
  • 3,940 Answers
In control panel, make sure that the mic is properly configured in audio devices (They don't always get assigned properly) so that the correct device is set for recording.
You can test the mic in sound recorder (Just type sound on the search bar, it should appear in the list)
Posted on May 16, 2008
My yahoo messenger voice call pc-pc working but the other side can never hear me! But if I use skype no problem. It used to work but may be because I changed my wireless router to Belkin! But I also turned...
Try running through your settings again
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger 10
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice
Set webcam mic and speakers to show Default equipment
Open Video and Voice Setup to test audio equipment
Click 'Place a free test call'
Check box 'Allow USB devices to access Messenger'
Click 'Apply' click 'OK'
May 15, 2010 | Yahoo Messenger
I cant make a pc to pc call, whats wrong?
Dear Friend You Need Following
  • Messenger
  • Audio card(It must be on your System if your System New)
  • Mic
  • Head set
  • Inter Net Connection
  1. Install Messenger
  2. Sign in Messenger
  3. Configure Audio (it will automatically configure)
  4. Add ID you want to call(ID is basically mail address of a person you want to contact;it is said to be Mail address)
  5. Click on ID
  6. Click on CALL button
  7. It will answer the person you want to call(He/She Should be on-line at the time of Making Call)
  8. You are Connected
Check this things..
  • CHECK YOUR SOUND CARD
  • Check your MIC
CONFIGURING.....Do following...
  • Open Messenger(there you will see at top Messenger,Contacts,Actions etc.)
  • Click on ACTIONS
  • Click on CALL SETUP
  • Click on NEXT (You will see a tab for Configuring Sound Set-up)
  • Try to Speak (you can see YOUR SIGNAL of SPEAKING)
  • You are Sucssesfully Configured MIC
  • Click Next (you will hear SOUND)
  • Click Finish
You are Done.. I tried to give you Detailed instruction.... is THIS tExT Helped YOu.....
Rate ME ....
Thanks For Using FixYa
Apr 02, 2010 | Yahoo Messenger
Pc webcam ywb-1016, video works, but audio(built-in mic) doesnt
You may have to tell your computer what mic you wish to use ( make it default )
Laptop/mic x webcam/mic x Vista x Yahoo Messenger
TEST SPEAKERS
In lower dropbox display "Use this device enable" click OK
Restart computer
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Jan 19, 2010 | GE EasyCam Webcam
My chatmate can hear me but i can hear her
might be ur speaker is not intgrated with mic give it for service
Dec 22, 2009 | Yahoo Messenger
Hi i am unable to do a video call or voice call on my ym 10
First, recollect was there any errors while you were installing YM 10, later think about settings in YM in order to make sure system compatibility and try to think about YM standards of your opposite person
Dec 14, 2009 | Yahoo Messenger
I lost sound on messenger, any remedies? Will a uninstall and reinstall work?
cheak the sound driver in your pc if its works then its problem of your messenger then u can remove your messenger and reinstall it if u have lost your sound from pc then put motherboard driver cd install your sound driver
Nov 16, 2009 | Yahoo Messenger
Person on other side cannot hear me
please check the microphone setting under audio setting under control panel ...
Oct 09, 2009 | Yahoo Messenger
My microphone not working in yahoo.
remove from control panel and re-install yahoo messenger again use 8.1 version.
Aug 21, 2009 | Yahoo Messenger
My yahoo messenger ver 9.0 got some sound problems...i can't use voice chat but howcome i got sounds when buzzed appear... my OS is vista anyways.
Sorry about this but you might have to uninstall the yahoo messenger you have and download version 10.0 http://messenger.yahoo.com/winbeta
This would so solve your problem.
Regards
John
Jun 30, 2009 | Yahoo Messenger
My Microsoft VX-5000 Lifecam Mic Won't Work In Yahoo & MSN?
Normal 0 See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
  1. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
May 15, 2009 | Microsoft Life Cam Vx-5000 Webcam
Dell Dimension C521 PC Desktop Logo
74 people viewed this question
Alun Cox
