Question about Saeco Vienna De Luxe Espresso Machine
Gfci trips. Hi - I have had my Saeco for 10 years now. Since earlier today the gfci trips whenever I am trying to use it. Any ideas? Thank you!
    Sergeant:
    Novelist:
  • 193 Answers
GFI safety trips whenever it detects moisture. Normally this happens when water splashes over when filling or brewing coffee. This has happened to me several times. You must dry the machine out totally inside and out. I have used a hair dryer successfully both times. It is possible that you have a short circuit. If you want to veryif that it is moisture and not a short circuit, plug your unit into an outlet that is not GFI protected. If it kicks the breaker, then you definately have a short circuit in the machine. This would require dismantling the machine to find where hot wires have come into contact with bare gound.
Posted on Sep 14, 2010
  • leonidas137 Oct 05, 2010
    Hi -
    Thank you very much for your answer. Saeco was fine for the last couple of weeks, now it is happening again. Just plugged it in a regular outlet and it worked. So, no short circuit....Any other ideas? Thank you again!
  • Harry Presley Oct 06, 2010
    If it works in a regular outlet but not in the gfi outlet, it is the same problem happening again. The gfi is sensing moisture somewhere inside the coffee maker. If you splash even a drop of water outside the reservoir and it seeps into the timer or on/off switch etc, or if a few drops fall from the brew basket while you are pouring coffee, it will kick the gfi, but not a regular outlet. If there is no obvious way that water is getting into the machine like that, it must have a very small leak somewhere inside the machine. It must be letting enough moisture out to kick the gfi, but not enough to leave a puddle of water under the machine. If you have a very small internal leak, it is probably going to be very difficult to find and repair the leak. Many times you will do more damage taking it apart than you can fix. As I see it. you can use the machine on a regular outlet, prevent moisture from getting into the controls, or replace the machine.
GFCI Breaker tripping when turned on
Try running the motor in the dark. You may find it arcs to the chassis of the motor and that is your culprit. Had same thing on a hot tub 10 years ago. The professional techs tried everything for me. i finished the last part at 10pm and turned the motor on and saw the arc then trip the gfci. Good luck
Jun 13, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
GFCI keeps tripping when pump is submerged
Install another GFCI
http://waterheatertimer.org/How-to-wire-GFCI.html
Do not use anything that trips GFCI in water.
Just get another one and be safe.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 30, 2013 | Pool & Spa
LG dryer is shorting
A seriously dangerous problem! Call a repairman immediately!
Sep 04, 2012 | LG DLG3788W Gas Dryer
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
2006 Chevrolet Duramax block heater trips on a ground fault circuit but works on an unprotected breaker. Why does it work on one but not the other? Will this damage any truck circuitry?
Hi Funny,
If a GFCI trips or causes a breaker downstream to trip, something needs to be altered. Do not by pass a GFCI. It is designed to save lives and property.
It's drawing a lot of current. The most likely cause is the cord you are using is too light (14ga. or higher) or too long.
Depending on the length, extension cords should be 12ga, minimum, preferably 10 ga. When in doubt, go heavier.
The block is supposed to heat up, not the wire.
Best regards
Mike
Dec 22, 2009 | Chevrolet Silverado 2500HD Cars & Trucks
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Big Chief smoker trips 20 amp GFCI
try to use another out let and see if it is the GFI outlet first if it trip the new outlet then you know it the grill and not the outlet
Jul 31, 2009 | Luhr Jensen Big Chief 9890
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Saeco Vienna De Luxe Espresso Machine Logo
436 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
