Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Red light temp comes on and tv turns off after a while of operating. The lamp was replaced a year ago and the set works fine until it overheats. I suspect one of the two cooling fans are not working properly. There has been a screeching noise from the set for a while which sounds like a dry bearing in a fan. I require to know the procedure to get access to these fans i.e. what parts of the tv enclosure to remove to get at them. I would also like to know the electrical ratings of the fans i.e. their specs. Regards-- Ron and I look forward to your reply
    Problem Solver:
  • 6 Answers
Hey thompsonsrj, basing my answer only what little I have learned about one part of your problem you pointed out the screeching sound... my tv also did this and I discovered through research that it is indicative of the Color Wheel going bad. It is a $100 or so dollar part and can be replaced with a bit of elbow grease. As far as the overheating, possible cooling fan issue, I am unsure if they are related? I hope this helps a little? Thanks, Will
Posted on Oct 21, 2010
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
TV won't turn on
you need to replace the lamp in your tv, it is easy and you can do it. Look on the sides of the set for a door labled lamp, with the set unplugged open it up and remove the lamp, if the bulb is out it will have lots of glass in the lens
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
TV Not turning on , but blue power light is on
look in the back, see if the lamp is actually lit. If it is probably not a tv problem. If you can pull up the menu then you probably are on the wrong input. Are the fans running when you turn it on? IF fans are running might be lamp, if nothing is seen through the back.
Apr 29, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
Sony kdfe55a 20
2 YEAR IS TIME TO RPLECE LAMP
Mar 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
