I have a Kyocera KM-C3232 MFP. It has not been in use for some time. I turned it on to check it this morning. It displayed an error message 'Call Service Error C7903' This machine hasn't been under service contract for a long time. Is there some way I can fix this in-house? I have tried to bring up the password screen to access the programming but can't get by the error screen. Any suggestions?
  • 12,061 Answers
When a machine like this hasn't been used for a while, and especially if it was not head cleaned , prior. Then you indeed have a problem, what happens is that the ink dries in the tubes and print head. This then needs to be all cleaned out, and replaced as maybe.
Whenever any Ink-Jet printer is to be stored or not used for a while, say a week or more, then a head clean and service should be done, even to the extent of cleaning out the waste ink tank/absorber as well. If one doesn't do this then as said before the inks dry up, inside the machine, inside the Nozzles, inside the print head too and this stops it from working.
So I would say that this is why the machine is telling you to contact the service center. As they would be the only people that would have the spare parts and knowledge to get this unit working again.
Posted on Sep 13, 2010
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Not scanning...error code 720f
Software trouble error code
720f Error: Unknown error
Causes:
Unable to determine the
cause.
Check procedures/corrective measures:
Turn the main power switch off and on.
Jan 14, 2011 | Kyocera Km-3060 Mfp Copier Copy Machine...
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
C6000 Error message on Kyocera Mita KM-C3232 Printer
the c6000 error may be resettable.
the password will be 3200 or 6482.
once inside you need to be in copy mode and do the following
punch into the keybord 1087 1087
once you see 000 on the screen punch in 163 and hit the green button
you will then see the reset sequence, follow this and it should work.
please report if this works
Mar 20, 2009 | Kyocera Mita Office Equipment & Supplies
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
59 people viewed this question
jasbo
jasbo
