Question about Rosen Necvox RE8269D Car DVD Player
I have a Rosen RE-8269D overhead DVD player and I need the power supply. Rosen's websire shows it as AD-6871 but only sells to dealers. anyone have any other ideas?
  • 3 Answers
SOURCE: cant find headphone socket for rosen in-car dvd player
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
Posted on Apr 09, 2009
  • 151 Answers
SOURCE: I have a Rosen A10 DVD Player that only one side
New screen
Posted on May 13, 2009
  • 55 Answers
SOURCE: My rosen dvd player doesn't work
could be a loose or weak wire connected in the rear. Did you have this professionally installed? I would check the wires before trashing. There are fuses in those units, maybe able to have fixed by a shop. Good Luck
Posted on Oct 01, 2009
SOURCE: Need a remote control for a Rosen DVD player
try ebay
Posted on Feb 28, 2010
gopakumarg43
  • 75571 Answers
SOURCE: Mounted rosen box on top
Hello
Have you checked your car video player Rosen R5505 properly. If it doesn't power up, connections may have some trouble.
This unit is exclusively for cars with a negative ground, 12V
power supply.
If your unit doesn't come up, check the 3AMP fuses connected in series with the main +ve power rail. There are three wires from the rear power socket, colured yello, red and black. Out of which Black wire is --Ve or ground.
Yello is meant for constant power +12VDC, and red is meant for +12v accessory supply.
Whe fitted in the car, the yellow wire is connected to the ON-OFF switch, to power the unit when needed and the red wire is connected before the ON-OFF switch, so that there will be power ot the control section of the unit to retain memory and all other previous setting levels. In otherwords, red wire must be connected ot the battery terminals, and yellow wire must be connected after the switch of the car. This is the wiring status when the unit is in the car. Black wire is meant for ground or cars chasis.
When the unit is powered ouside the car, the red and yello wires must be shorted and connect to the +ve and the black to --ve. Then obly the unit will live up. OK.
Posted on Dec 10, 2010
Rosen overhead DVD player won't eject
It is cheaper to replace it than try and find someone who can fix it.
May 03, 2018 | Rosen Car Audio & Video
How to wire domelight in rosen overhead dvd player
put dvd purple wire to the car gray wire your traverse has positive trigger. Hope that works , switch has to go to positive on dome switch . Please post back if that works.
Jun 27, 2012 | Rosen G10 Car DVD Player
Why does my DVD start over from the beginning when the car is turned off then back on. I just had my player replaced in the car I bought due to some malfunctions and the old one used to resume where it...
Not sure of the price difference but, the reason that your unit does not "remember" where it left off on the movie is because there is no memory connection. Most units have a 12 volt battery connection (memory), 12 volot switched (accessory) and ground connection.
Mar 26, 2011 | Car Audio & Video
Rosen CV6880D scheme
I have a big problem, I recently bought a van DODGE GRAND CARAVAN 2002 model, in this coming Rosten CV6880D player installed, but I want to play DVDs or CDs including the speaker not working. please help.
you show me one tutorial or manual
Feb 04, 2011 | Rosen CV7080D Portable DVD Player
Rosen dvd player will not turn on - just purchased 2005 land rover lr3
check the owners manual for fuse locations and find the fuse for your dvd system. make sure it isnt blown. if it is, replace it and see if it blows again. if it does, or if the fuse isnt blown, take it back to the dealer and get it checked out on their dime
Jan 12, 2010 | Rosen CV7080D Portable DVD Player
No power
Hi
Check the fuse for it if you haven’t yet.
May 22, 2009 | Rosen CS700DVD Car Show 7.0 7 Inch...
Overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Apr 08, 2009 | Rosen A7 Car DVD Player
Rosen a7 dvd player
Hi there, sounds like the ribbon to the screen is broken.
Mar 11, 2008 | Televison & Video
Rosen Necvox RE8269D Car DVD Player Logo
99 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
