Question about GE WBSE3120B Top Load Washer
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
  • 121 Answers
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
Posted on Sep 13, 2010
Ge 9 min light flashing
I broke down and had a technician come and fix it for me. It ended up being a loose wire in the panel.
Apr 22, 2013 | GE WBSE3120B Top Load Washer
GE WBSE3120B toploader washer leaks only during agitation when super load selected. Is it the pressure switch for water fill level or another possible leak?
knowing this is the only time it leaks helps
sounds like your suffering from suds leak
try cutting way back on your soap 1 tablespoon per load that should take care of your issue
Oct 04, 2009 | GE WBSE3120B Top Load Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
GE top loader washer water keeps running will only cut off at faucets"
If disconnecting power does not stop the water fill, replace the washer's inlet water valve. It is the part the fill hoses screw onto on the back of the machine.
May 20, 2009 | GE WBSE3120B Top Load Washer
GE Washer Motor over amp?
If that's the only thing wrong with it, then go to http://www.appliancepartsdepot.com
They are about the most reasonable priced place I have found.
Dec 24, 2007 | GE WBSE3120B Top Load Washer
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Have to hit start button several times over first few minutes, due to it shutting off. I think it may be a faulty switch?
I have the exact same problem.. (I suggested I'm going to replace the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303) found one for $45 at partadvantage.com
Nov 15, 2007 | GE WBSE3120B Top Load Washer
GE WBSE3120B Top Load Washer Logo
347 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
