Question about Haier Freezers
Model HUM046EB compact upright freezer. After defrosting it will freeze with frost and ice inside. Door gasket does not appear to seal properly. Where can I purchase new gasket if you think this is problem?
  • 2thdoc656 Sep 14, 2010
    What else could it be other than gasket?
  • 2,382 Answers
Hi, you definitely need to replace the door gasket. You can get the door gasket from Repair Clinic on 1-800-269-2609
Posted on Sep 13, 2010
  • Tunde Autos
    Tunde Autos Sep 14, 2010
    Sure about it...
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Ice and frost
Excess frost especially near the door is caused by door gaskets being bad. The gasket should hold a dollar bill snug.
Another possibility is auto defrost failure. - Remove the cover on the rear inside the freezer to see if the coils are heavily iced.
Aug 13, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Just defrosted my freezer and is akll frosted over
When you say it is frosted over, do you mean the interior of the freezer is frosted, or the evaporator coils?
A couple things to check for:
1. Is the door gasket making a good seal when you close the door? A good quick fix for a bad seal on the gasket is to rub a thin layer of Vaseline (the original jelly kind works best) on the rubber to help it stick and to fill any scratches that might be keeping it from sealing tightly.
2. Is the fan running on the inside of the freezer? The evaporator coil in the freezer needs a fan to blow air over the coils to keep them from freezing over. They don't run continuously, and on some units will turn off when the door is open, so try holding the door switch shut when you check.
3. Is the defrost cycle working? Frost-free freezers have a defrost cycle in which a small heater turns on to thaw any frost that has begun to form. To check the functionality of the heater and the defrost timer will probably require a visit from a technician... It would take a while to explain it here, but if check the first two and come up empty handed, post back. You will need a volt/ohm meter.
I would check the first two
Mar 24, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Freezers Logo
97 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
