Question about ASUS A7V400-MX Motherboard
Is this suport sata hardisk? - ASUS A7V400-MX Motherboard
  • ASUS Master
  • 11,800 Answers
As is now, no. You need to add a PCI SATA card for that - $15 at almost all IT shops.
Posted on Sep 13, 2010
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
SATA Hardisk canot read into bios.. the sata cable is brandnew and SATA hardisk is also new
You will need a RAID driver for your motherboard. Contact your motherboard manufacturer for assistance.
May 23, 2011 | Computers & Internet
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
Did not detect the additional sata hard disk?
Have you tried connecting the SATA hard-drive to a different computer, just to prove that it is not a "dud" ?
Is the SATA hard-drive getting power?
(It should warm-up a bit, and you make feel it vibrate as it spins.)
Have you tried a different SATA cable between the hard-drive and the SATA connector on the motherboard?
Check the BIOS settings, to be sure that detection of SATA drives is "enabled".
Apr 09, 2010 | Computers & Internet
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
Suport hdd sata intel d865gbf?
The Intel D865GBF motherboard.
Supports 2 Serial ATA (SATA) connectors, see page 39 in your manual.
The serial ATA SATA ports will support Version 1.5GBs SATA drives not 300GBs
If you no longer have your manual, download it from Intel. Click on the link below;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22d865gbf%22
Mike
Oct 15, 2009 | Intel D865GBF Motherboard
I cannot install software
Hi..
This happen due to 3 reasons,
The Hard drive is bad.
The BIOS Setting have to be put to SATA.
During the the installation the have to press the F6 option to install the SATA drive drivers.
Let me know
Thanks
Smith
Aug 09, 2009 | ASUS P5LD2-VM Motherboard
Need SATA hardisk driver for DOS
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
SATA HARD DISK DRIVERS FOR DOS
OR
DOS HDD DRIVERS FOR SATA
OR
DOS DRIVERS
OR
DIRECT OPERATIONAL SOFTWARE
ROD
Mar 05, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
I have a new 8ogb sataII Exelstor hardisk which i
Windows XP does -not- have native SATA support and therefore will not recognize a SATA drive without first installing 3rd party drivers.
To go around this problem without installing drivers check your BIOS. There might be something in there where the bios will emulate an IDE controller.
If not, you'll need a floppy and the sata drivers. A flash drive will also do if the motherboard bios supports legacy USB. To find the drivers, simply go to the motherboards manufacturers website.
Mar 03, 2009 | EPoX EP-8KRAI-X Motherboard
Formating hardisk with sata connection
1) Be sure that your motherboard support SATA - See Bios
2) Using the Win XP installation CD you can format the drive. If you cannot load windows during the installation hit F6 to charge the SATA drivers.
If your sata drive is working like a second disk, you can format it directly from windows.
Start>> Control Panel >> Admistrative tools >> Computer Management
Or using any partition tools...
Sep 23, 2008 | Seagate Computers & Internet
ASUS A7V400-MX Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
