Question about Mtd Garden
Ohv130 206820b will not start not getting fuel can the carbs be adjusted the only screw i see is on the float bowl. I did take apart and cleaned with carb cleaner. also the rear tires seem to "lock up" and not turn when pushing it
    President:
  • Mtd Master
  • 1,545 Answers
If you removed the bowl bolt for the carb, make sure you cleaned ALL the tiny holes in it (bottom and sides) as this is the main jet. An OHV mower engine periodically needs the valves adjusted. Don't panic...its easy to do and there are may tutorials and You Tube videos on this. Properly adjusted valves (should be checked about once a year) are likely to only help your no start issue.
Posted on Sep 14, 2010
I need to know the proper tuning of ucal mikuni carburetor with mixture adjusting screw on bottom of cabr (beneath float bowl), an idle adjust screw and pilot screw (hopefully pilot fuel screw since s
Why did you need to clean the carb? Routine servicing of the aircleaner would keep the carb clean for life. The pilot screw should be 1.5 turns out approx. with a small adjustment either way. Idle speed is set to a smooth low idle.If this doesn't fix it have you got something in the carb not replaced correctly? The float needle/float assy? How did you clean it? Have you introduced fluff/dirt into the carb and did you blow it clean with an airline?
Oct 09, 2014 | Motorcycles
CARB ADJUSTMENT
The Float adjustment usually involves carefully bending a tab against the needle valve where the fuel enters the float bowl. Since the float, "floats", there is no external adjustment. The float should close the valve at a specific height, and open as the fuel level drops, thus controling the level of fuel in the bowl, which in turn controls the amount of fuel being ingested by the carb. As for cleaning, any over the counter fuel system cleaning additive will help with that, from any auto parts store.
May 11, 2013 | Motorcycles
Generator not running
This sounds like a jet is plugged, if fuel is getting into the bowl. You need to take apart and blow out all of the jets. (The secret on the adjustment screws is BEFORE ANYTHING, measure EXACTLY how many turns clockwise, until the screw (jet) bottoms out. Then you can get back to an adjustment that is at least close, when you're done blowing everything out.) Pull the carb, use spray carb cleaner and blow all passageways out... remove any particulate matter you find....
While there, also clean the inlet (float) valve, but now with cleaner, if it is a rubber looking seal area. You just want no chunks of foreign material.
Nov 24, 2011 | Electrical Supplies
Fuel bowl on my 50cc scooter keeps empting and killing the engine I keep adjusting the carb fuel screw on the carb but I still have the Fuel bowl empting. Does anyone know if I need to turn the fuel screw...
It has nothing to do with the adjustments, what is going on is your float is stuck in the carb , you will have to take the float bowl off , float is sticking than you will have to try and clean the needle and seat valve.
Sep 07, 2009 | RTO Gas Motor Scooter
Craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
Jun 24, 2009 | Craftsman Garden
Corrossion in fuel tank . difficult starting.
For the corrosion in the fuel tank get a liquid tank liner. It lines the fuel tank walls then hardens to seal the tank from rust. Google “ kreem fuel tank liner “ or go to www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html
For the hard starting, clean the carburetors. (unfamiliar with your bike, I assume it has carburetors and not fuel injection).
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetors. There should be a screw on the lower side or bottom of the CARB float bowls. Remove the drain screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carbs to fill with gas. Install new stock NGK spark plugs and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
FOR EACH CARB > Remove the float bowl and clean the entire CARB with a spray CARB cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the CARB. Remove the idle screw and the air screw on the outside throat of the
CARB and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
CARB back together, clean the air filter and install the CARB. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Jun 12, 2009 | 2000 Moto Guzzi Nevada 750 Club
Fuel draining out as soon as filled
ALWAYS have a fire extinguisher at hand when working on carburetors.
This is a carb float being stuck open.
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times doesn’t free the float and fix the overflow problem, remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please top rate this solution. Thanks!
May 08, 2009 | Yamaha Camry Motorcycles
Engine conked out whilst riding then wouldnt start untill 20mins
Drain the carburetors. There should be a screw on the lower side of each carb float bowl. Remove the screw then replace it after the fuel drains. Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, (not all bikes have a water trap bowl). Turn the gas back on and wait a minute for the carbs to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetors from the engine.
FOR EACH
carb > Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the carb and spray into the screw holes as well.
carb back together, clean the air filter and install the carb. Install an in-line fuel filter. Let the float bowl fill then start the engine. This process should get you back on the road.
Also, sync the carbs such that the slides on both carbs move at the same exact instant when the gas is slowly increased from idle speed.
Apr 29, 2009 | 2001 Yamaha XVS 125 Dragster
My yz 125 02, is splutering and is strugleing to pull off in 1st gear, i am told it is running too rich and i need to ajust the fuel mixture screw. How do i find this??
The fuel mix screw is otherwise known as the idle screw.
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. If there is still a problem, then remove the slide from the throat of the carb and move the clip on the jet needle down one notch. This process should get you back on the road.
Apr 28, 2009 | 2003 Yamaha YZ 125
Fuel Leak from the Carburetor
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Check the float as they can go bad and fill with gas such that they no longer float. Remove the idle screw and the air screw on the outside throat of the
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. The idle speed will probably different so adjust the idle screw to get back to where it was. This process should get you back on the road.
Apr 23, 2009 | 1987 Honda CBX 250
Garden Logo
118 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
