Question about Whirlpool LER4634J Electric Dryer
It is fine for one load but the next it stops compleatly and wont turn back on
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 14, 2010
My yz 125 dirtbike is stuck in 1st gear while its off and wont start up
try to compleatly shift down then half up with the clucth in
Sep 14, 2012 | 2003 Yamaha YZ 125
Holds water wont compleatly drain shuts down before spine cycle
Hello
If the washer shuts down before spin cycle it indicates that it is unable to drain properly. Please check the drain hose/drain pump filter for any clogs/blockages and try cleaning them to solve this problem. Also after cleaning check if the pump is working fine.
Kevin
Nov 10, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
THE WASHER DOES NOT COMPLEAT THE CYCLE IT STOPS AND Codes IE
Are all taps turned on, is the filters in the hose connections clean? The code means it is not getting water, if water supply is ok one of the valves may be faulty.
Apr 18, 2010 | LG WD-3274RHD Front Load Washer / Dryer
Pin won't return fully. And won't load the next staple...
It is an import stapler similar to a Bostitch. The oring inside the poppet valve is worn. This prevents the driver from coming back all the way. Compleatly rebuild this tool
Apr 03, 2009 | Air Tools & Compressors
Laptop wont turn on
Try removing the battery and plug in the power adapter and then power on your laptop. If this doesn't work, put the battery back in and plug in the power adapter and try turning it on. If that doesn't work then take the power cable out and try with only the battery. Try in this order and see if it comes back up, if not, you may have some dead hardware.
Mar 12, 2009 | Gateway M305CRV Notebook
Washing machine wont stop?
you have a bad timer assy, youll need to replace your timer
Mar 23, 2008 | Washing Machines
ITunes Library Problem
try reloading itunes again with out your virus cheaker or your fire wall this will a low you to load it back a gain compleatly
Jan 08, 2008 | Apple iPod nano 3rd Generation
Whirlpool LER4634J Electric Dryer Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
