Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Replacing an ICM SC2201 thermostat with hunter 44155c and cannot get it to work
rizla
  • 1463 Answers
SOURCE: need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Posted on Feb 26, 2008
SOURCE: hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Posted on Jul 13, 2008
SOURCE: 3 Month baby and need help hooking up thermostat ASAP
The wire colours mean nothing. If your old one didn't have letters or you already disconnected it, you will have to go to the furnace. Under one of the panels there will be a control board to which the thermostat wires connect and this might have the letters printed on it. Trace them back and connect them appropriately.
If you have a furnace that is like mine (a single-stage natural gas one), chances are that R is +24V, C is common, W is heat call, and G is the blower. Y is generally cooling. The furnace could be turned on by connecting R, W, and G together, I suppose, if the above doesn't work... but it won't shut off automatically.
Posted on Jan 28, 2009
milten1
  • 1304 Answers
SOURCE: Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Posted on Oct 17, 2009
kingbrizzle
  • 407 Answers
SOURCE: Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Posted on Jan 23, 2010
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermostat need manual
Hi
u can fine your manual here...
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Gary
Feb 28, 2008 | Computers & Internet
Need help !!
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44155C Thermostat
Try calling hunter directly at 1-888-830-1326 to speak with a live support representative. If you are still having problems.
Jan 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
100 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
