Question about Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum
My carpet shampooer has poor floor suction. It sucks very little of the water back up?
  • 1,040 Answers
Check to make sure that any/all intake vents are not blocked by debris. If that's o.k., then you need to replace the belt(s). Once the belts get stretched, they no longer work properly. This is normal and happens as a result of regular usage.
Jim
Posted on Sep 13, 2010
How do i fix this problem rug dr shampooer leaving water in the carpet
hmmm thats a lil odd may need to check the connections to the hose and to the floor unit of the vac for any damages or other issues
Apr 21, 2017 | Vacuums
My hoover max extract dual v stopped sucking up the water on just its second use. Any ideas on how to fix this problem?
The most likely problem is there is a restriction somewhere or a suction leak. Check to make sure you have good suction where the waste water tank fits down onto the machine. Make sure the lid is on the waste water tank and follow the flow of suction from the machine through the waste tank down to the floor and look for debris clogs or any area where there may be a suction leak. If you have good suction coming from the machine the problem has to be somewhere between there and where the water is being sucked off of the floor.
Oct 24, 2013 | Hoover MaxExtract Dual V Carpet Cleaner...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
I have the bissell x2 12 amp carpet shampooer
The water should be picked up fairly rapidly into the area surrounding the clean water bladder. Try checking the lint filter to fix your suction problem. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). One the under side of it there is a small (1 inch square) red filter with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre. etc.. Clean it out and you should have suction.
Jul 09, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will not **** up shampoo
It sounds like a suction problem. Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use). It is a small red filter, about 1 inch square, with a little door on it. Flip open the door and you will probably find it is clogged with hair, carpet fibre, etc.. Clean it out and your suction problem will hopefully be solved.
Jun 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Apr 13, 2009 | Kirby G6 Bagged Upright Vacuum
Carpet steamer does not **** up the water
take a look at the back side of the suction of the unit. first there's thre ront pies\ce of plastic then there is another. somtimes the secind piece becomes broken and the suction of the unit is wiped out.
Jan 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Kirby Sentria
Your shampooer is not broken. (sorry Fanny)
You are missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box. Here's a link to my online Kirby shampooer instructions...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped!
Marci
Nov 05, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Carpet shampooer
hi, I used to sell these, and can tell you that they are not designed to suck up the water. They are made to put a limited amount down and then the brushroll scrubs it. Then it drys and ideally you would vacuum up the dried residue that is left. I own one myself, and admittedly the shampooer is not as good as the ones that steam clean and suck it up, but it does ok. The longer you sit in one area, the more water is going to go down, so keep it moving. And remember that it is going mostly at the middle of the unit, so it's good to overlap a bit. If you have troubled stains, I can suggest spraying some type of cleaner on it and going over it with the brushroll--like windex. My buddy also used to sell them, and that worked for him.
Sep 02, 2007 | Kirby Heritage II Vacuum
Ultimate G Shampoo System
Follow these instructions next time you hook up the shampooer.
As for the bead, you need to lift the nozzle of the power head up and ver the bead to pick it up. The nozzle makes a great suction seal with the carpet and that's why it's pushing it. If you tried that, make sure that the green light on you nozzle is lighting up. If not, you either need to change the belt or make sure you hasve it on properly. For help with this, here's another guide...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Aug 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum Logo
154 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
