Question about Whirlpool Dishwashers
I have a Whirlpool dishwasher mod. number GU2400XTP6 the clean light flashes then stoppes when the start button is pushed. the light on the start button flashes three times and stoppes then the clean light starts flashing again the machine dosen't start. I've checked the micro switches in the handle release and they are working fine. will I have to replace the main computer module? If so were do I get it and how much dose it cost?Thanks
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Posted on Jan 22, 2009
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
sclarke7
  • 222 Answers
SOURCE: whirlpool dishwasher model number GU3600XTSY2 is
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Posted on Mar 26, 2010
My dishwasher will not start the heated dry light flashes constantly
Hello Daneil, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool 24 in. DP940PWP Free-standing...
I have a whirlpool dishwsr. model GU2400XTPB7 that has been flashing the normal light and I cant use it for over a week. I turned off the breaker to the house for 30 min. & that did not work. I tried...
Hi Melinda,
Thanks in advance for using Fixya.com. Now then firstly by pushing the heated dry and normal buttons then repeating is the proper procedure to reset the control board,below is a the exact buttons to push to reset the control. Also please take a count of the number of times the light flashes befroe going off breifly then repeats the same number of flashes; the number of flashes indicates a error code...if if flashes 5 times that error code 5 and if it flashes 7 times its error code 7 etc,etc.. please get back to me with the number of times it flashes.
Here is what i copied and pasted from my online service manual for Whirlpool dishwashers that shows which buttons must be pushed to reset the board,after pushing the buttons shown push the cancel/off button and the board should be reset so the machine will start at least one time where ya can take note of the number of times the nirmal light flashes,
GENE
Mar 01, 2012 | Whirlpool Dishwashers
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
I have a quite partner 2 and it is stuck on the clean cycle and the light is blinking on and off. It will not work when I push any other buttons.
whirlpool dishwashers sense the water temperature in them the clean light flashing 7 times means either the heater element is not working or the water temperature going into the unit is to cold, start the water at the sink before starting the dishwasher now to get rid of the flashing light press the hi temp wash button and then the sani rinse button press one then the other over and over until all the lights come on it will then go in to a test mode when it completes the flashing light will go out that will solve your problem
Apr 03, 2010 | Whirlpool Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Constant flashing clean light
count the blinks shoud be 7 times it blinks then a pause if it does that its a heat circute problem need to check the heater and replace the controls
Jul 13, 2009 | Whirlpool Dishwashers
Mar 26, 2009 | Dishwashers
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
54 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
