Question about Hotpoint HTS16HBR Top Freezer Refrigerator
I HAVE A HOTPOINT REFRIGERATOR AND LATELY IT DOES NOT GET COLD ALTHOUGT THE TOP FREEZER IS FINE I TOOK THE THE REAR PANEL OFF INSIDE THE FREEZER AND IT WAS FULL OF ICE WHAT CAN BE CAUSING THIS PROBLEM AND IF I COULD FIX IT MODEL # HTS16GBRFRWW
    New Friend:
  • 50 Answers
Defrost your unit for about 2-3hrs..check the fan fan if the bushing has no wiggle, make sure the damper that control the air from top going to fridge is open..you can also check the timer of defroster if it is still working
Posted on Sep 13, 2010
I HAVE A HOTPOINT FZM80 UPRIGHT FREEZER. THE INSIDE BACK OF THE FREEZER IS SWELLING LIKE A BELLY. THIS IS FORCING THE DRAWERS OUT AND THE DOOR WONT SHUT. ANY IDEAS?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Hotpoint Refrigerators
Hotpoint FFA90 fridge freezer, fridge not cooling but freezer OK, was told vent proabaly blocked and to de-ice. Turned appliance off for two days, turned back on worked fine for 1 week but now fridge is...
i have the same problem. took apart the vent in the fridge at the top and thought maybe it needed replacing as that controls the amount of cold coming up from the freezer, but there doesn't seem to be any cold coming through. does anyone know if this is 'blown' through by a fan of some sort?
Jun 14, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer not freezing, fridge seems too cold
If the refrigerator is in the house and the temperature in side is between 60 and 80 it should be able to hold good temperatures. If it is in a garage or outside it will not work as well.
If it is inside the first thing to try is resetting the controls. Turn the Fresh food control to a low setting and the freezer setting to maximum. Wait 24 hours and recheck. If this does not work you will need to replace the cold control. To find the part number you will need the complete model number located on the tag.
Apr 18, 2010 | Frigidaire All Refrigerator & Freezer Kit...
Refrigerator won't stay cold but freezer works fine.
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Hotpoint sidebyside--freezer back panel has ice on it.
It could be the defrost timer the defrost heater or the defrost termostat You can check the heaters for continuity or when the freezer is all cover with ice turn the timer (located in the cold control box inside the refrigerator ) untill the compresor stops and if the heaters start glowing the timer is bad.
Jul 22, 2009 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
FRIDGE NOT COLD FREEZER WORKS FINE
Make sure the freezer fan motor is running. Remove the rear panel in the freezer and check for frozen coils. If coils are frozen replace the defrost heater and thermostat.
Check the air vents to the fresh food section,are they frozen closed?
Jul 17, 2009 | Hotpoint HTS16HBMWW / HTS16HBMAA Top...
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Whirlpool ET22DK NOT Cooling
Hi, Is the compressor running at all? Are the fans running? Whe you took the rear panel off in the freezer, was there any frost on it at all?
Vic
May 17, 2009 | Refrigerators
Water drip from freezer to refrigerator
Defrost drain line in the freezer is frozen shut.
Remove the freezer panels.bottom and back panels.
Remove the visible ice.
Take a hair dryer and thaw the drain hole in the center rear drain trough.
Mar 12, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
242 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
