Question about GE Profile JGSP48 Gas Kitchen Range
Igniter keep firing, this started after cleaning
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 14, 2010
I have a Dayton 3E437A furnace that does not activate the igniter or solen.
Try the flame sencor looks like a small rod this may need cleaning but if you jumped ou tthe pressureswitch then this will need to be replaced , check air filter is clean .
Oct 20, 2011 | Dayton Gas Furnace Heater
What is the meaning of 98 Honda Civic error codes P0300 P0303 P0304? Engine will not start, does not seem to fire.
P0300 indicates that there is multiple miss fire in the ignition system. P0303 and p0304 indicates the miss fire is in cylinder #3 and #4. Replace the spark plug, and wire set, and rotor and cap if there is one. Can not remember if there are coil packs on the civic, the age thing. change the fuel filter and clean out the fuel injectors with fuel injector cleaner for the next 3 full ups. When the spark plugs are removed, inspect them for condition, if there clean or dirty with carbon build up. which would indicate how the engine is running. Keep me posted and drive safe.
Jun 04, 2009 | 1999 Honda Civic
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Problems in wet weather and cleaning my triumph won't start.
Water is getting into your ignition coils.
Trace the spark plug lead up to the coil.
Get some ignition sealer spray and spray loads of it on the leads and coil.
When a bike is new, it is sealed. After washing with detergents it gets washed away. Spray the leads and coil once a week to keep them totally dry.
An immediate way to get round when wet is to spray wd40 on the leads and coil, it should start straight away.
But, don`t spray ignition sealer on until it is totally dry.
Hope this helps
Jan 26, 2009 | 2004 Triumph Triumph Bonneville
Igniter keeps firing
The problem resolved on its own. I'm guessing some moisture from my cleaning was the culprit...when the moisture dried the igniter stopped sparking.
Jun 01, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Igniter
igniter's are bad and, or, a short in the wiring or switch. replace the igniter, then check to see if problem still exists, you can also check wires going from igniter to switch with ohm meter for continuity and shorted wires.
Nov 18, 2007 | Frigidaire PLCF489AC Dual Fuel (Electric...
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Sep 21, 2007 | Frigidaire FGF326AS Gas Kitchen Range
GE Profile JGSP48 Gas Kitchen Range Logo
185 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
