Question about Newco co NKL3AF Three Station Pour-Over Coffee Brewer
I have a Newco Coffee Maker Model # NKLP3AF I think part number 110305, PDS Flow Valve, is cracked and is leaking. Does anyone have a photo of this valve so I can compare to be sure that is the correct part number?
  • trhodarm Sep 14, 2010
    Thanks for the info. but do you know what it looks like?
  • 10,865 Answers
Hello. Here is a free link to the owner manual in the pdf format http://www.retrevo.com/s/Newco-NKLP3AF-Coffee-Makers-review-manual/id/3879ag209/t/1-2/
Just download it to see exactly what you have. J.
Posted on Sep 14, 2010
  • 2,272 Answers
PDS Valve Assembly, Low Flow ACE IH A,FC:---- (((((110620))))))). PDS Valve Only, Low Flow FL x PLGA,FC (((((110305))))))). Click this link directly for all the parts list:-- http://www.newcocoffee.com/pdf/parts/parts_401k-20050317.pdf ------------- Cost of this valve is near to $83. You can order this valve from the link below.Click on it:----- http://www.dccoffeeproducts.com/newcoaceparts.html -------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 13, 2010
How do I stop my newco ace-lp 3 burner coffee maker from overflowing
try cleaning the fill probe. if that doesnt work make sure your inlet solonoid isnt stuck open. or it needs a new board.
Jul 16, 2014 | Newco ACE-LP 3 Warmer Low Profile Coffee...
Adjusting water flow Newco coffee machine
replacements parts for NKL3AF:
front switches for upper front & rear not plates and for the brew start/ready green lamp
Can I download the users manual/guide too?
thanks
Manuel Florez
(787)609-4115bsat4ube4gblqiaaaaasuvork5cyii=
Feb 17, 2014 | Newco Coffee Makers & Espresso Machines
Have an ace lp that drips even when turned off and fills pot to overflowing any suggestions on correcting problem
Hi. you have a solenoid that has got a piece of lime scale stopping it from completely closing, You can try doing a Descale cycle which should flush it out. If its a plumbed in model, its hard to stop the leak with the mains water pressure, otherwise drain the steam out, when you turn off the machine. The steam pressure if left in the machine, can keep it dripping. Darryn REPAIRER
Sep 23, 2011 | Newco ACE-LP Coffee Maker
Water leak on a Bunn coffee maker model B8W, leak only when brewing a pot of coffee
Where is the leak coming from? If it is from the back of the unit or the bottom then it is cracked and you will just need to replace the coffee maker. If it is leaking from the top then it is a seal issue in the water valve that brings the water from the tank and into the coffe filter and into the pot.
Apr 26, 2009 | Refrigerators
Cuisinart DCC-1200 BW Model leaks by morning if I put water in the night before to have coffee made by program. More water on the counter almost as in the pot. Any solutions? Bought 4/5/07
Order 1 foot of 5236K73 "High-Temperature Silicone Rubber Tubing" from McMaster-Carr. Put the old check valve in the new tubing in the same location and direction as originally installed.
Sep 22, 2008 | Cuisinart DCC-1200 Coffee Maker
NEWCO manufactured 1989 model RC-28F
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Aug 28, 2008 | Coffee Makers & Espresso Machines
Help
I finally found the phone number for Back to Basics, and they said they re-designed it and sent me a new carafe free of charge. It lasted for a couple months and it's doing the same thing. You can continue to use it. My husband says the metal expands and contracts, so if after it brews you pour it into a coffee container before the heater turns off, you can still use it. It only leaks after the coffee cools and the metal contracts. Hope this helps. Here's the phone number. We all need to call and I'll call again as well. 866-290-1851 The model number is: CA0307
Nov 27, 2007 | Back to Basics CC500 12-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
255 people viewed this question
Top Newco Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Newco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
