Question about HP OfficeJet 6110 All-In-One InkJet Printer
Right cartrige incorrect
Error:
right cartrige incorrect, can someone tell me what the problem is?
  • Vanessa Quintal May 23, 2008
    I inserted the right cartridge i clean it out like the manual said i let it dry and it still keeps giving me the message of to remove and check the right cartridge. I don't know what is the problem.
    Vanessa
Well I tried everything everyone mentioned even for different brands as this problem is not with this brand alone, relentlessly I tried cleaning both sections unplugging and what nots so I thought to myself the problem would be with the ink being somewhat stuck on at the point of conception to the prineter so I took it and heated it up with my blow dryer (to get the ink to flow) common sense to me......wala after messing around for 2 weeks with this problem 1 simple brain storm by a woman and solved...! forever and a day guys ......! Jenny
Posted on May 18, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
This error means that the printer is unable to read or load the cartridge.
Try to rub the golden parts on the cartridge with a smooth damp cloth.
And in the contacts where the cartridge has to be placed also clean it.
Now install the cartridge & check.
Are you using the compatible cartridge with the printer, this message will came if the installed cartridge is not compatible with the printer.
Check with the known good that is the cartridges which you know that worked with the printer to make sure that there is nothing wrong with the printer.
If the error message comes call the manufacturer to checkand replace the cartridge.
Good Luck.
Live, Love, Laugh.
Posted on May 15, 2008
SOURCE:
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark x5070.left cartrige incorrect.replaced,still says left cartrige incorrect.
I had a cannon do that to me. It was the print head. Cheaper to replace printer, than a head.
Jan 30, 2011 | Lexmark Office Equipment & Supplies
My dell 962 printer was working fine. Then the next time I went to use it, the malfunction light was blinking and I had the message "right cartridge incorrect". I took it out and back in, unplugged and the...
You can try a new cartrige...and I would check to see if it's under warrenty. And there also a proccess for resetting the unit / master reset...it's in your product quide.
Thanks
Feb 20, 2010 | Dell 962 Photo All-In-One InkJet Printer
Have a Dell photo all-in-one printer 962. When it is turned on, it says "right cartridge incorrect" even though the cartridge has ink.
Try pulling out cartrige.Starting printer without it.Then turn it off and put back cartrige.Start it again.
Also, many other printers have problem in recognizing ink level. So just print until you see there isn't any more link left.
Sep 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
Wrong cartridge
Nice Printer.
First of all, see if its reading on the computer, if not, try and hold the power on the printer untill it shuts off, and then turn it back on again. Also, you might want to check the troubeshooting section if you have the manual
If none of the above works, try getting a replacement cartrige. if the connectors on the cartrige get messed up, the printer may not read the cartrige properly. Make sure the printer's connection to the cartirdge is ok too. If you know someone who has the same printer, try the "ERROR" cartrige in that printer. if it works, then your printer needs to get fixed. If it doesn't work, get a new cartrige and all should be fine. Don't get the cartrige refilled if it doesn't read in a nother printer, you need to replace the cartrige!
Jul 17, 2008 | Computers & Internet
Printer says right cartrige is incorrect
remove the cartridges and reinstall them back, turn the printer off , if that does not work, did you use a new original cartridge or a recycled cartridge ?, either way will trick the printer into the new cartridges, i, hope this solves the problem good luck.
Jun 01, 2008 | Dell 922 All-In-One InkJet Printer
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Apr 04, 2008 | Canon FAX-JX200
Incorrect cartriges installed
Any answers here? http://www.fixya.com/support/p473587-hp_officejet_v40_all_in_one_inkjet or go to HP web site for printers Tech Help
May 17, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
140 people viewed this question
Clive
Clive
Thomas F. Schneider
