Question about Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
CDRW/DVD CRX835E Drive won't format or write to a DVD-R disk. Does read DVD movies and music. No problems with the CD R/W functions.
  • 1 more comment
  • piotrjodlow Aug 22, 2008
    I've got the same problem; crx 835e recognize cd-cdrw but don't see DVD. It has been imidiately, during working???
  • ebrahim714 Dec 06, 2008
    my sony crx835e dvd drive does not write or burn to disk
  • Anonymous Jan 21, 2009
    crx835e plays only music and some vcd but its not playing any dvd
    Champion:
  • 230 Answers
That is b/c you only have an CDRW/DVD ROM (from your title). You need a DVD+-R to be able to write to a dvd+ - R disk.
Posted on May 15, 2008
Need a driver for SONY CDRW/DVD CRX835E
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Aug 07, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I have dell inspiron 6000 my combo drive is not recognizing dvd format movies although it is supporting cd formate
Hi Fazi1814,
If you're issue is that the dvd drive could not read the cd at all then you might want to try deleting upper and lower filters from registry editor. This files from windows sometimes cause an issue to your drive/
Here are the steps on how to locate and delete them:
1. Open Registry Editor - go to Start then type regedit on start search box then enter
If you get any notification just click continue
2. Once window is open, Look for the following subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10
To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. On the right pane, select upper and lower filter, right click then delete.
4. Click Yes when prompted
5. Exit registry editor and restart the computer
If your issue is that the drive reads the disk but it does not play the movie. This could be an issue with the movie format. Not all movie format can be played by the windows media player. In this case you need to have either of the following: (but I suggest you get both)
1. K-Lite Codec Pack 7.10 (Full) (to be able to read almost all types of movie and music format)
2. VLC Media Player 1.1.8 (can read any kind of format without installing any codec but still recommended to have codecs installed)
You can try downloading this two software from www.filehippo.com.
Hope this works!
Thank you for using Fixya,
avf110686
Apr 05, 2011 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
MY SONY CRX835E-DF CDRW WILL NOT WORK. i AM TRYING TO FIND A DRIVER FOR IT TO FIX THE PROBLEM
Hello mychella513, hi, there is no need for you to find the device driver for your sony combo, because its already present in windows. If you cannot power on the device or the computer cannot detect your drive, its defective, Windows has already installed the device driver for CD/DVD for your computer.
Aug 09, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Redone windows xp.... now cant burn dvds
There are dozens of free perfect functioning  burning software. the one that i use is Totally Free Burner 3: as the name says it's free, extremely small ( just 1 MB compared to 100MB for Nero), fast and very easy to use. get it from here http://www.softpedia.com/get/CD-DVD-Tools/Audio-CD-DVD-Burning/Totally-Free-Burner.shtml
Jan 21, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
In side device manager sony cdrw/ dvd crx835e shows an explaination mark... cds, and dvds aren't able to be read from the drive
it means that your driver for that device is not completely install. so reinstall the driver.
thanks for your question
Jan 10, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My DVD/CDRW only reads commercial dvds
My hl-dt-st cdrw/dvd gcc4244 ata device cannot write on DVD-rw imation cd why. How to resolve this problem
Dec 23, 2008 | Teac (DW224E/S) CD-RW/DVD-ROM (Combo)...
Sony CRX835E CD-RW/DVD-ROM (Combo) Burner Logo
493 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
