Question about Kitchen Ranges
I have a BOC 250R MIG welder and need to change polarity on it for flux cored wires is it as easy as swapping the leads on it or is there another option.
  • Kitchen Ranges Master
  • 43,501 Answers
Yes, swapping leads will reverse the polarity....
heatman101
Posted on Sep 14, 2010
How to reverse polarity on transmig 195 for gasless wire
just take the lead for the wire and attach it to the ground terminal and attach the ground wire to the + terminal
there will be diagrams in your user manual and if you don't have a manual then go google and type in--- user manual for mig welder 195 model( model not included in your question)--- and there will be a psd version to down load
Dec 30, 2015 | Welding Tools
Can a millermatic 35 mig welder be changed to use fluxcore wire ?
with flux core wire the torch is supposed to be negative but there are people using the fluxcore without changing polarity.
its as simple as swapping the polarity to the torch and and return clamp
Feb 15, 2015 | Welding Tools
Can I use 0.030 Flux Core Wire in my Lincoln Electric SP170-T?
Use the .030 flux core wire with the amperage settings for .023 solid. If you cannot find .023 settings then just set low power first and play with it to see what works.
Aug 26, 2014 | Welding Tools
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
Mig gas conversion for JobSmart 125 Flux Wire Welder
The other difference between gas/gasless is the ability to reverse the gun polarity which you can't do with a gasless only welder. You can get it to work but not safely and reliability could be an issue also.
Mar 06, 2012 | Welding Tools
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Mar 20, 2011 | Campbell Hausfeld Welding Tools
Have solar 110 2172 mig welder does this mig use gas can i use flux core wire also is owners manual available
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Dec 26, 2010 | Solar Mig Welder Welding Gun Liner Parts...
Getting lots of splatter weld will not hold
Check polarity of machine.
Solid wire with gas assist will need straight polarity ground clamp to negative side.
Flux core wire no gas, need reverse polarity; ground cable to positive side.
Oct 27, 2010 | Clarke Power Products Clarke 130EN...
Kitchen Ranges Logo
141 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
