Question about Philips 23PF9945 23 in. HDTV-Ready LCD Television
I have got a philips modle 42PF5521D tv we got a problem when we turn it on it will go from a red light to a green light but only flashing and no picture we have to turn it of and on at the plug till we hear a click and a reb light to work
  • 188 Answers
Several capasitors in the power supply must be replaced.
Posted on Sep 13, 2010
Philips 42PF5521D will not switch on
The main digital board should be suspected. Check this for more details. There are so many reasons for this fault. The flashing of LED at its front panel denotes this. Count the number of flashes. You can get more details form the site linked above.
Dec 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Tv wont come on , and green light keeps flashing, tv model 42pf5521d/hd
Hallo! You might have a power trouble. Open the rear cover and take a look over the power board- that's the board where goes the alimentation cord. Look if there are not inflated the electrolytic capacitors, if yes, you must change them with the same type. Be careful with the polarity of the capacitors- you must solder them the same way as the old ones were.
May 13, 2011 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Flashing green ligt----------intermittent
Many problems with philips can be solved by doing a software update which is done with a flash drive in the USB port. The only problem is your model number dosen't show up on philips web site. You may want to try to email them from their site to ask why your's dosent exist.
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=AEN&scy=US
Mar 13, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42pf5521d - no picture, blinking green light
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Aug 17, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
My philips got green light on no pic.
Press and hold the menu button on the side and hold for five seconds, that will reset the tv ------------- do this after you have checked your manual for other troubleshooters, you know, the obvious 'correct channel i.e EXT1, EXT2, TV'
Nov 06, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Philips 23PF9945 23 in. HDTV-Ready LCD Television Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
