Question about Dishwashers
I have an intregrated diplomat ADP8501 dishwasher. For the past 8 months it has had a problem. When you start it up it works fine for the first couple of minutes and then it seems to cut out and on again, the light goes off and on for about 3 mins and then it continues working properly. This might also happen again mid cycle. Is the machine on the way out or is there anything I can do to fix it.
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
bigg t
  • 640 Answers
SOURCE: Diplomat dishwasher blows fuses
I would disconnect the heater then run the unit.If it runs the heater is bad,if the fuse blows again the motor is most likley bad.make sure there are no water leaks.let me know.happy holidays
Posted on Dec 06, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
  • 131 Answers
SOURCE: my diplomat dishwasher keeps stuttering
Did you find the cause of your dishwasher problems?
Posted on Mar 17, 2008
SOURCE: ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
Posted on Jul 16, 2008
Diplomat ADP8342 won't fill with water
Assuming the water tap is open and the water pressure is correct, it is likely the inlet water valve in the dishwasher is faulty. If you hear a click at the time the cycle starts but still there is no water then the inlet valve needs to be replaced. Also check the inlet hose for any kinks or blockage of the filter attached to the tap inlet.
The inlet valve looks like this item
Diplomat ADP8342 Solenoid Valve
Aug 05, 2014 | Dishwashers
Diplomat Dishwasher Power going off and on
if you are looking for the answers related to your dishwashers problem then you gotta check out this link it's nice and simple easy solutions can solve your problems in just few minutes..
Check them here : Bosch Dishwasher Error Codes E15 E22 E01 E09 Error Codes Pro
Mar 30, 2017 | Dishwashers
My Frigidaire dishwasher will not start. It was working fine about a month ago. The lights on the panel are working and I had the water line checked and it is o.k. I cannot find a serial number but the...
My Frigidaire 500, 1100, 1400, 1500 & 2400 Series Dishwasher was purchased a month ago and it will not start either. The 8 second lock under "Heat Dry" is lit, but nothing happens when you press any of the other buttons. Any ideas?
Mar 27, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
Dec 16, 2010 | Ovens
Diplomat adp8322 dishwasher has start button flashing 7 times and rinsne cycle light on what does this mean
This is stating that no water is entering the dishwasher.
My solution was to turn the power off at the wall and wait for 10 minutes.
Turned it back on. Pressed the Start button and held til it beeped and reset, then started as normal and all was fine.
Jan 02, 2010 | Dishwashers
Diplomat Dishwasher motor cutting out on hot mid cycle
Hi ,This problem is your main wash motor the origonal is an ascol
motor ,but the replacement is a motor with copasiter costs
around £80.00 for new motor
Nov 19, 2009 | Dishwashers
Diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Nov 14, 2008 | Dishwashers
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Oct 21, 2008 | Dishwashers
Dishwashers Logo
134 people viewed this question
Top Dishwashers Experts
