Question about Weather King 10AJA3001AH Air Conditioner
10 seer weatherking contactor switch stuck.have been using astick lol but serious had to wedge stick all summer to push in switch .now all of a suddon it stuck. asking why i ha to push in switch and why it might have stuck ?
    Sergeant:
    Novelist:
  • 193 Answers
The contactor is supposed to turn the condensing unit on when everything else is right and the thermostat calls for cooling. There are various sensors that can keep the contactor from activating. If you are low on freon, if the inside coil is iced over, if the freon pressure is too high or alternatively too low, if there is no air flow to the inside coils and when the thermostat says it is cool enough, the contactor will kick the unit off. The contactor works off of low voltage signals sent from various sensors. When all sensors say ok the contactor pulls in the 220 volts. Because you are pushing the button in manually, you are over-riding all the sensors. It is something you are not supposed to do. To determine the exact cause, you would need to follow the wiring diagram to each sensor to see which one is showing a fault. Manually holding the contactor in can cause severe damage to your unit, if it hasn't already done so. As to why it is stuck on, there is an electromagnetic coil that pulls the main contact points together. The contacts may have overheated and welded together, or the magnetic coil may have burned out and swelled up enough to prevent the rod mechanism to back out of the coil. I would strongly suggest you have a good AC technician trace out your system to find the fault.
Posted on Sep 13, 2010
Outside unit want shutoff
Stuck contactor most likely or thermostat still engaged. Tap on contactor to see if it releases. Call Aire Serv if not
Oct 18, 2013 | Rheem 13AJN36A01 3 Ton 13 SEER Air...
What size is my weatherking unit model 10ajb36a01
It is a 3 ton, 10 seer unit. Size is basically good for 1200 sq. ft. Hope this helps!
Jun 21, 2011 | Heating & Cooling
A/c outside unit is not working- fan will not work.
I assuming that the black box is a 100 amp breaker, which is connected to your condsensing unit (outside unit). If you open the box and pull the fuse then this will turn off/kill the power to your unit. As far as the buzzing noise it could be that the contactor is engaged. Hopefully, your fan motor is burnt out or the capicator is bad. If you take the access cover off and check for voltage at the contactor you should know if it is the fan motor. The voltage will come in at the bottom T1 T2 T3, once the contactor is engaged L1 L2 L3 will have the same power. Of course if your contactor is not engaging then thats the probelm, you can manual engage the contactor by pushing it in. There will be four wires two running to the capicator and the other to the contactor, these are the wires that control the fan motor. The other three wires run to your compressor. Hope this Helps Tim
Aug 03, 2010 | Heating & Cooling
Compressor is not engaging
This is probably not the answer you're looking for but the best solution is to have a qualified HVAC tech check it out. The porblem could range from a relatively inexpensive electrical part (capacitor/contactor) to a burned out compressor. Without being familiar with the Weatherking model numbers my guess is you have a 10 SEER 3 ton unit, which means it's pretty old. might be time for a enw one - at least get the tech to check it out.
Good Luck!
Jun 01, 2010 | Weather King 10AJA3601AH Air Conditioner
I have a weatherking 13AJA60A01 Ac unit and the condensor fan is not moving, I can hear a sound assuming electricity goes through the system but the condensor fan not working. The unit is just 1 year old...
Weatherking has five year parts on there equipment. You may just have a breaker kicked or tripped float switch. Check for stopped up drain Shop vac **** out stoppage from the outside drain line for unit. Check breaker. The sound you here maybe the contactor. It energizes from the tsat inside. If the contactor energizes. You have a high voltage problem. Your warranty covers aprts not labor. So call a Rheem ,Ruud or Weatherking dealer. Any of these dealers can handle warranty parts. Rusty Feadback please.
Jun 13, 2009 | Weather King 10AJA3601AH Air Conditioner
2 TON WEATHERKING HEAT PUMP VIBRATION AND NOISE.
Your friend is correct. Installing a sump or p-trap in the suction line will probably help. The oil may be leaving the compressor but can't get back.
Feb 23, 2009 | Weather King 10AJA6001AH Air Conditioner
Weatherking control board
the fan comes on only after the burner fires. so no stat voltage is expected. it is not powering the blower, the elec board is. only after burner lights will fan be energized due to heat build up. usually on older weatherking there is a heat sensor on the bulhead above the burners. it is stuck sounds like to me. try a sharp rap on the right side about four feet up the side and a foot back . if fan stops you know the switch was stuck . probably needs a new fan switch.
Oct 20, 2008 | Heating & Cooling
A/c help
Do you have 24volts at the contactor when the T-stat. is set to cool or heat if unit is a heat pump? The outside unit must have 24v at the contactor to engage
Oct 19, 2007 | Hitachi RAS-09UH Air Conditioner
Weather King 10AJA3001AH Air Conditioner Logo
137 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
