Question about Ohaus Measuring Tools & Sensors
Balance is giving me a Err 8.2 message when it is turned on. Unit is an analytical plus model AP250D
    Problem Solver:
  • 9 Answers
The error 8.2 is pretty general. Most likely it is caused by damage to the load cell. There are some things you can try before you decide to get the balance repaired.
1. Turn the balance off and unplug it. Count to 20 and plug it back in anf turn it on.
If that does not work.
2. Put a 100g weight on the platform (the weight does not have to be exact).
3. Plug the balance in and wait for the count down. If the count down starts at 99 you can stop this procedure will not work. If the count down starts at 255 continue.
4.The balance will read error 8.2 again at the end of the count down.
5. Unplug the balance.
6. Remove the weight.
7. Plug the balance in and wait for the count down. The balance should count down and turn off.
8. Turn the balance on and it should work normally.
If this does not work the balance needs to be repaired.
Posted on Jan 26, 2011
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
Not Graphing
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If that's not it, post a comment and we'll go from there.
Apr 08, 2010 | Texas Instruments TI-84 Plus Calculator
I can't open any progrmas on my TI-84Plus , it only gives : Error and 1:QUIT can you experts help me?THNX
You should give the whole error message.
I created a bogus program and archived it.
Then I tried to execute it. I got the messages: ERR Archived 1:Quit 2:Goto. When I tried to edit it I got ERR:Archived 1:Quit.
Your program is archived. You must unarchive it.
To Unarchive. Press [2nd] [MEM][2:Mem Mgmt/Del] [ENTER]
Scroll down to [7:Pgrm]. Archived programs will have a star at the left. Highlight the program you want to unarchive and press [ENTER]. The asterisk disappears. Press [2nd][QUIT]. Your program is ready to run or to be edited.
Hope it helps.
Sep 23, 2009 | Texas Instruments TI-84 Plus Calculator
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Google Analytics Results
Dont worry about that..
Insert the google analytics code in all pages and track it.
Dont depend on others... See i use analytics, sitemeter from sitemeter.com and stats from histats.com
but after some days i removed histats becoz it is showing more than is and up to my knowledge
analytics and sitemeter are accurate.
Thanks
Mohan
Oct 05, 2008 | Google Analytics
Error message on camera
I had the same problem, what I did was set ISO to manual,and still got the Err,but I took a shot and the film advanced and it seems to be ok now.
Mar 25, 2008 | Nikon N80 35mm SLR Camera
S3 pro and studio flash
I have Fuji S3 pro and One body locked up during a reception and ERR displayed. 1st i turn off and on . it is work ok. 2nd time it happen again and still show ERR on dispayed. no way to reset. my camera out of warranty. estimate cost for repair 400$ per manifacture.
Dec 26, 2007 | Fuji FinePix S3 Pro Digital Camera
Measuring Tools & Sensors Logo
3,450 people viewed this question
Top Ohaus Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Ohaus Measuring Tool and Sensor Expert? Answer questions, earn points and help others
