Question about LG WM-2277HW Front Load Washer
Code LE - LG WM-2277HW Front Load Washer
  • 15,935 Answers
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Thanks for using FixYa%^&*
Posted on Mar 04, 2011
Codes deblocage de nokia 1661-2b mon nokia ne reconnait pas les puces francophone on m'as dit qu'il me faut un code pour ca aidez moi slvp
Salut il ya plusieurs fa?ons de d?bloquer le
mobiles, nous pouvons utiliser le logiciel, le c?ble, les codes etc ... parmi les
les codes sont les meilleurs. Aujourd'hui, il existe de nombreux sites en ligne qui fournissent trouv?s
les codes pour d?bloquer le mobile.you pouvez obtenir les codes d'ici l? ils demandent classicunlocking
les d?tails suivants sont mod?le mobile, le pays et le r?seau qui verrouille votre mobile, l'IMEI
num?ro du mobile. Enfin ils vont envoyer les codes pour d?bloquer le mobile.
Sep 26, 2011 | Cell Phones
Unlock code for adobe reader LE 2.5 for nokia x6
NOkia c5-03 Mobile imei 357925047286064 unlock code Adobe reader LE 2.5.15,.Please Send to my mail satria_ronika@yahoo.com
Sep 18, 2011 | Nokia X6 16GB Cell Phone
Quelle sont les etapes que la manette universel fontione
Lorsque vous souhaitez programmer un dispositif trouver le premier code.
Ensuite, appuyez et relâchez le bouton que vous souhaitez attribuer le code,
Ensuite, appuyez et maintenez enfoncé le bouton SETUP jusqu'à ce qu'elle occupe une lueur.
touché les numéros de code. il devrait clignoter deux fois, en indiquant un code de bonnes.
puis cliquez sur le bouton que vous venez de configuration, et le diriger vers le périphérique, et cliquez sur le bouton d'alimentation.
Si elle vient, vous avez choisi le bon code
Il ya généralement plusieurs codes pour une marque, afin de les essayer tous, un par un jusqu'à ce que vous avez.
Répétez la procédure pour d'autres articles. Soyez sûr d'assigner une touche différente et appropriée labeld.
Aug 31, 2011 | One For All URC4110 Remote Control
Samsung bloqué par opérateur
Qu'est-ce qu'un code PUK? Un code PUK (Pin Unlock Key) est nécessaire lorsque vous entrez un code PIN erroné 3 fois. Après avoir entré le code PIN erroné 3 fois, la carte sera verrouillé et vous devez obtenir un code PUK auprès de votre prestataire de service pour le déverrouiller. Que devez-vous faire si votre téléphone dit Entrez le code PUK Code? Vous pouvez recevoir des appels de code PUK de votre de fournisseur, soit en vous connectant à votre compte sans fil à mon compte; visitant notre Chat d'assistance technique ou en téléphonant au service à la clientèle. Une fois votre code PUK a été reçu, il sera nécessaire d'entrer dans votre téléphone pour définir un nouveau code PIN.
Si le mauvais code PUK est entré 10 fois d'affilée, la carte SIM devient invalide (verrouillées en permanence) et vous devrez acheter une nouvelle carte SIM. Le téléphone affichera «PUK bloqué opérateur d'appel» ci-dessous. Si votre périphérique a besoin d'PUK 2 s'il vous plaît appelez à la clientèle: soins. Pour obtenir votre code PUK, en log myWireless compte et suivez les étapes 1. Sélectionnez Téléphone & Device 2. Sélectionnez le lien Débloquer la carte SIM 3. Suivez les instructions sur le pop-up page Comment débloquer votre carte SIM Vous aurez besoin de votre téléphone dans la main afin de débloquer votre carte SIM. 1. Tout d'abord, entrez le code PUK chiffres 8, puis appuyez sur OK / Oui:. Remarque: Certains utilisateurs de téléphones Motorola devrez entrer ** 05 * si "Entrez le code PUK» n'est pas déjà affichée. Après avoir entré ** 05 *, puis entrez le code PUK chiffres 8 et appuyez sur OK. 2. Choisissez un nouveau code PIN, puis appuyez sur OK / Oui. 3. Re-entrer le code PIN, puis appuyez sur OK / Oui. 4. Si les codes ont été conclus avec succès, le téléphone est prêt à l'emploi.
J'espère que cela vous aide, ecuse mon mauvais français.
Dec 04, 2010 | Samsung Computers & Internet
Forgot code for door lock codes
nissan maxima 93 que je mettre le shifter sur le d le n le r elle reste sur lepark mon chum doit ouvrir le capot et gosser aores kchose quelle est le probleme
Jul 11, 2009 | 1993 Nissan Maxima
Jai un remote 1.5 echostar 429.718 et je veut men
Oui. Dans ton manuel ExpressV, ils expliquent en page 3-10 et les codes sont en pages suivantes.
SI tu n'as pas le manuel, voici:
Le code de Sharp sera un de ceux-ci: 628, 605, 608, 740, 526, 585, 591, 606, 607, 629
Appuyer sur le bouton TV du remote jusqu'à ce que les quatre boutons blancs allument;
Entrer le code de sharp (par exemple, 628) suivi du #. Le bouton TV clignote 3 fois.
peser sur le bouton rouge (power). La TV derait se fermer. Si ça ne fonctionne pas, réessayer avec le code suivant, 605, et ainsi de suite.
Mar 17, 2009 | Sharp Televison & Video
Arr?t de la laveuse amana
Code 2E demande l'assistance d'un technicien. Remplacement du module de contrôle électronique. Problème réglé par le vendeur. Excellent service.
Jul 26, 2008 | Washing Machines
Verroulliage sim
si tu vu, faire le mauvaise code 3 fois - il va tu demander pour le PUK - apres tu doit contacter votre fournisseur pour le PUK et faire rester votre SIM.
merci
Jan 31, 2008 | Samsung SGH-D500 Cellular Phone
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
