Question about Sharp Actius A250 Notebook
HOw do you remove the HDD - Sharp Actius A250 Notebook
    Guru:
  • 689 Answers
To put it in easy terms all computers are constructed in a module way using plug-in connectors for each pheripheral item,or ribbon cable etc.
When it comes to laptops this is the case also but bear in mind space is limited so things have to be compact and fit flush etc,
get yourself a fine screwdriver set and see if indeed your pc is user-serviceable
Posted on Sep 13, 2010
How do I change an HDD in Fujitsu Siemens DT7-D2264?
Remove any external power source and laptop battery. Turn the laptop over and remove the screws that hold the cover. Remove the hdd.
Sep 19, 2014 | Computers & Internet
Remove password hdd toshiba mk3275gsx
1. The HDD password cannot be removed using Security Assist.
2. Using SETUP BIOS (i.e. start machine; Hold Esc; Press F1), Tab to the HDD Password section which should be displayed as follows:
HDD Password
HDD = Built-in HDD
HDD Password Mode = USER Only
User Password = Registered
3. Tab to the "User Password" field and simply enter the old password and then a new one twice (once to verify) as one would do normally. If you don't want a password, just press "enter" twice.
Hope above steps helps you. :)
Nov 12, 2013 | Toshiba MK3265GSXN - Hard Drive 320GB 2.5"...
Will not see disk in drive
Unplug, remove battery, Open HDD bay, reseat HDD, Close HDD bay, plug in, reboot, if no change , remove HDD and test, replace if necessary.
Dec 28, 2012 | HP Computers & Internet
How can I replace my defective HDD on my Sony laptop model VGN-SR210J
remove the screws for HDD from the back side of laptop... remove the screws that holds the HDD...
replace the old HDD with new HDD...
place the screws back and close the lid...
Feb 06, 2011 | Sony VAIO VGN-SR210J/B 13.3-Inch Laptop...
I have a gateway zx4800-03 and I need to know how to remove the hard drive to put in a new one
I removed one on a Gateway ZX4800-02. Remove two screws by the usb ports on the back. then remove the plastic piece covering the usb ports on the back. This will expose the HDD. Now to make it easier. remove the four screws holding the support bracket and remove support bracket. remove the three screws holding the HDD located up, right, and left. Now disconnect the HDD cable by pull it to the right by the connector. DO NOT PULL THE CABLES. My friend does that by habit all the time and it drives me crazy.
HDD should come out easy. Just remove the metal cage covering the HDD and Replace. Reverse order for reassembly.
Now does anyone know how to get off the damn front bezel!>!!?!?!?!? I can't figure it out.
Dec 08, 2010 | Computers & Internet
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
How do I access the hard drive (to replace) on a Canon imageRUNNER 5000. Where is it located/how do I remove it?
Points to Note When Replacing the HDD
1. Take care to avoid damage by static charge.
2. Keep the HDD unit from impact.
1) Remove the rear upper cover and the
reader rear cover.
2) Remove the three screws , and detach
the cover.
3) Remove the two screws , and disconnect
the two connectors ; then, remove
the HDD unit.
4) Remove the six screws, and detach
the HDD.
When mounting the HDD unit, be sure that the flat cable is under the plastic sheet of the HDDupper case.
here is a link to the location of the HDD http://i51.tinypic.com/htvitg.jpg
Obs:
1) Replace the HDD unit.
2) After assembling the machine, connect the power plug to the power outlet.
3) Connect a PC to which the Service Support Tool has been installed.
4) Turn on the PC, and turn on the main power switch while holding down both '2' and '8'
on the keypad.
5) Using the Service Support Tool, format the HDD unit and install the system software.
Nov 16, 2010 | Canon imageRUNNER 5000 Copier
I want break my hdd password and laptop bios password
Bios password can usually reset by removing laptop battery and clock battery from motherboard, but HDD password as i know cant remove. You should change your HDD.
Apr 09, 2009 | Acer Aspire 4720 Notebook
Hard drive is full
Aquire disk imaging program such as norton ghost. Install 2nd, larger HDD into existing computer. Boot computer using ghost boot disk. "Image" existing HDD to newer, larger HDD.
Remove existing HDD. Set 'new' HDD to proper position (Master, etc).
Boot computer.
Joy.
Feb 19, 2009 | Microsoft Windows XP Professional
Looking for Toshiba HDD for M35-S320
you can buy the HDD in your laptop at computer shop, but check first if it is SATA or IDE...under your laptop,there are 2 screws remove that and remove the HDD and check what type of HDD you have..here is the idea, with 40pin its indicate IDE with small flat connector its SATA..remove and check and go to computer shop,they will ask you also how many GB you want...80,120,160 whatsover..buy and replace the HDD.
Nov 03, 2008 | Toshiba Satellite M35-S320 Notebook
Sharp Actius A250 Notebook Logo
56 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
