Help! I have an HP M2727 that is jamming when I use the duplexing feature. Changed out entire maintenance kit and the issues continue.
    Genius:
  • 1,478 Answers
Around the solenoid, there's a gear with one-way bearing inside it, and it's playing up. it drives the roller shaft that feed the paper in the duplex tray. you can try cleaning and lubricating the one-way bearing. but if it's still not good enough you have to replace it. Once the solenoid is replaced, the problem should be solve.
Take care.
Posted on Sep 13, 2010
How to remove paper jam from duplex unit
No issues i share a informative links please visit and read it.
Read more help... How to fix printer paper jam andHP Printer Support
Thanks,
Aug 26, 2014 | Ricoh Aficio SP C820DN Laser Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
HP M2727 paper starts to pick up and apparently jams just above the paper tray #2.
http://www.amazon.com/HP-P2015-2015-Roller-Maintenance/dp/B00965WQYI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1377471140&sr=1-1&keywords=rk-p2015Hello,
It sounds like the pickup roller is not getting a good grab on the paper. When this happens the roller can not push the paper up into the printer where the next rollers can grab it. this is a very common issue after a year or two of use. The pickup rollers and separation pads come in a kit that is available on Amazon here: http://www.amazon.com/HP-P2015-2015-Roller-Maintenance/dp/B00965WQYI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1377471140&sr=1-1&keywords=rk-p2015
Aug 21, 2013 | HP Laserjet M2727nf Multifunction Printer
HP 4700 printer, paper jams in duplexer
Paper pickup assy. The guide to send back through is broken or missing
Feb 13, 2013 | HewlettPackard HP 4700 CP4005 Duplex...
HP Laserjet M2727 Printer picks up too many pages at once
You have worn pick rollers. This is an easy fix and you can install the new rollers yourself. You need a preventative maintenance roller kit part number RK-P2015. You can get them here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_70&products_id=128
The kit has all of the rollers and separation pads to replace the worn ones in the printer to restore proper operation.
I hope this helps,
BuddyMc
Jul 20, 2012 | HP Laserjet M2727nf Multifunction Printer
Hello. We are getting an error on our HP Laserjet M2727 saying "Jam in cartridge area". We have tken everything out and cannot find a jam anywhere but the error continues. How can I reset it? ...
Remove catridge life registration assm plate check there might be small peces or sensor might be dusty.. easy method with air blower clean under registration assm....
Sep 14, 2011 | HP Laserjet M2727nf Multifunction Printer
I had several paper jams and now after clearing the paper, I have a jam every time I do a double sided paper o my hp laser jet m2727nf.
You will need to get a maintenance kit for it.
It will have rollers and pick ups in it that need to be changed.
If that does not work the duplexer will need replaced.
Jul 02, 2011 | HP Laserjet M2727nf Multifunction Printer
Hi, My hp k550 is blinking at lights 1 and 4. How can I fix this problem please? Thanks
Issue
The power light and resume light is blinking.
Power light and resume light is blinkingc01576793.gif Solution one: Press the resume button
Load paper in the paper tray and press the resume button (c01219285.bmp ).
Try to print the job. If the issue continues, proceed to the next step.
Solution two: Clear the paper jam
Step one: Clear the jam from the back and top of the product
  1. Remove any paper loaded in the output tray.
  2. Turn off the product.
  3. Push the button on either side of the rear access panel or duplex unit and remove it. Figure 7: Removing the rear access doorc01576794.jpg
  4. Locate any jammed paper inside the product and pull it out towards you.
  5. If there is no jam, push the latch on the top of the duplex and lower its cover. Figure 8: Lower the product coverc01576795.jpg
  6. If the jam is there, carefully remove any jammed paper and close the cover.
  7. Replace the rear access panel or duplex unit.
  8. Open the top cover.
  9. Check for and remove any jammed paper by gently pulling it out.
  10. Make sure that there are no scraps of paper stuck between the rollers.
  11. Close the top cover, turn on the product, and resend the print job.
Try to print the job again. If the issue continues, proceed to the next step.
Step three: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Cause
The product might be out of paper or there might be a paper jam.
Feb 28, 2011 | Office Equipment & Supplies
Hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Jan 31, 2008 | HP LaserJet 4300n Printer
Auto Duplexing lost with Vista drivers
The in-OS and the Full Feature release drivers for some of our products have a problem with doing duplex jobs.
Start a command window as an Administrator
Hit Windows Key (or CTRL and Esc Keys Together) Choose All ProgramsAccessories CMD Prompt – Right Click and Choose RUN AS ADMINISTRATOR When to prompt comes up click CONTINUE to allow the Command Prompt to run as an Administrator.
Stop the Spooler service - Type net stop spooler
Change current directory
Type cd %windir%\system32\spool\drivers\w32x86\3
Backup the old gpd files – Type copy hp*.gpd *.bak
Extract the files from the zip file to correct location
extract files to %windir%\system32\spool\drivers\w32x86\3 directory
Remove old BUD file Type - del HP*.bud file
Restart to spooler service - Type net start spooler
Print something duplex to test.
Thanks
Mac
Jan 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
64 people viewed this question
k24674
