Question about Sony Playstation 3 (PS3) Console
Can i hook up my ps3 to a wired internet - Sony Playstation 3 (PS3) Console
  • 39 Answers
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connectioncan i hook up my - x_button.jpg x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Posted on Sep 13, 2010
HOW DO YOU HOOK UP A PLAYSTATION 3 TO THE INTERNET
It can be done via a wired and a wireless connection. For the wired connection, you just need to hook the ethernet cable at the ethernet port on your PS3. For the wireless connection, you just need to set it up under the Network Connections on your System Settings for the PS3.
Aug 23, 2010 | Sony Playstation 3 (PS3) Console
How do I connect my ps3 to the internet and tv so as to view the net on tv?
It's a semi-long process. Do you have a wireless router hooked up to your computer? If so just go to settings then network settings in your ps3 menu. If you have the wireless router then put wireless connection and its straight forward from there. If it is a wired connection and hooked to your ps3 than put wired connection and again its straight forward from there.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
How do i connect my ps3 to the internet if i dont have wifi?
Your PS3 supports both wired and wireless. Heres how I have mine set up, Ive been running wired since day 1. 1st- hook your ps3 up to your modem or router with an ethernet cable. {im assuming ps3 is plugged into the tv, if not hook it up}
2- go in to your network setting on ps3.. If you start at the far left go over click and all the way down. You will see network settings. click on it and go down to the 3rd option there.. Internet connection settings. You will get a pop up that says your ps3 will be disconnected from the internet if you proceed, just hit ok. It usually automatically detects if you have the ethernet cable plugged in but just in case it doesnt go ahead and select wired. after that, just select auto for everything else. You will go through about 5 questions and it will be ready to do an internet connection test. All should be well.
If that doesnt work, make sure all the cables are plugged in and try again.If you are able to connect to the internet after that but get booted off, go back into network settings again and disable the media server. Hope that helps.. Happy Gaming
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
Having trouble hooking internet to my ps3
are you using a wired connection or are you using a router
Apr 30, 2009 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wired connection
Hi There.
If your PS3 is Networked upto Your PC to use the internet connection, You have to allow the PC to share its Internet connection with yout PC, Do this By going into Network settings, Checking the properties of your LAN card in your PC. and clicking on, "share my internet". This should alleviate that problem..
Or.
If your PS3's Wired connection isnt working. but your PC one is, Try moving your PS3 Lan cable into one of the other Free LAN Ports (if available) or Try Switching the PC cable over to the PS3's Port in the Router, and Visa-Versa !
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 probems with usb router
Plug the router into the modem provided by your internet service. Then hook up the router to your comupter with a wire. Then go to settings connections on the PS3. then hit find networks. It should find your. Follow the on screen intructions.
Feb 22, 2008 | Sony Playstation 3 (PS3) Console
I need help with my ps3
did you hook the ethernet cable from the modem to mthe back of your ps3(wire internet)
do you have a wireless router(wireless internet)
are you trying to hook it up wire or wireless
Feb 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
