Question about LaCie (301065U) 500 GB USB 2.0 Hard Drive
My external drive will work with a firewire 400 but will not work with the usb with both cords plugged in. The harddrive is recoginzed on device manager but does not show up uncer computer. I previously followed your instructions for reformatting and establishing a drive letter on the drive. At school there is one other person with your drive that is having the same problem in getting it to work with a usb cord
  • 158 Answers
SOURCE: La Cie porsche drive not showing up on my computer
is the drive set on slave or master or cable select if this is the case then chane jumper setting toi master if booting with it on secondary ide but if on first ide then slave and if you have got files on these drives move them off then goto disk manager and delet partition then create new partion and sormat drive then set active in manager properties now reboot machine then open my computer to find the new drive hey presto working hdd
Posted on Aug 14, 2007
  • 317 Answers
SOURCE: Hard Drive does not show up on desktop
If you have access to a secondary PC or laptop, try connecting your drive to it using a different USB cable. Also try unplugging your drive from the power outlet for a few seconds and then connecting it again. Or you can try leaving it plugged in while restarting to see if it is recognized. Does your computer recognize other things you plug into it? If not, plug and play might be disabled.
Posted on Aug 23, 2007
bob_computer
  • 3153 Answers
SOURCE: I have a Lacie 320gb external harddrive which was
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Posted on Aug 28, 2009
Testimonial: "really straightforward just don't know what a drive letter is?"
hari007_in
  • 138 Answers
SOURCE: hard drive makes a clicking sound and does not
if the harddisk is making clicking sound,, then there may be an failure of motor inside it,,, ,, nothing but giving your HD for replacement by manufacturer
Posted on Sep 29, 2009
  • 126 Answers
SOURCE: I have a LaCie Rugged Drive, with multiple
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Posted on Jul 31, 2010
I have an avastor hdx -400 20gb external hard drive. No usb port! Just firewire.How can I connect the avastor to my pc from firwire port to usb port! Jeremy
Looks like a simple converter would do it. Might want to look into possible performance loss with it, though.
http://www.google.com/products/catalog?hl=en&pq=1tb+g3&xhr=t&q=firewire+to+usb+converter&cp=18&qe=ZmlyZXdpcmUgdG8gdXNiIGNv&qesig=EzFXII2T-aMubKk95tNsOQ&pkc=AFgZ2tn1nV8pBQPZgV7g7LWQbPmuymNt7ZG1sQeB2B5Y0Nvf6Keb_NjiFtNT1omWw27KlDcfodNcvW_mQYa_QlO-_enY53dclA&bav=on.2,or.r_gc.r_pw.&biw=1680&bih=939&um=1&ie=UTF-8&tbm=shop&cid=9131055957012417894&sa=X&ei=11AtTs3kD8ecgQe4ldWfCw&sqi=2&ved=0CGwQ8wIwAQ
Jul 25, 2011 | Avastor HDX-400 250 GB FireWire 400...
I have a Maxtor OneTouch 4 Plus 500GB external harddrive...I originally used it on a really old dell desktop computer but since then recieved an HP pavilion laptop...the laptop has windows vista. At one...
1.) Right click My Computer
2.) Click on Manage
3.) Click on Disk Management at the left side panel of Computer Management
4.) Right Click on the USB device in the Disk Management panel
5.) Click on Change Drive Letter
6.) Assign an Alphabet from E-Z to the USB device
7.) Click Ok
Go to My Computer and find the drive letter that you have assigned.
Hope it helps.
Jun 02, 2017 | Maxtor OneTouch 4 Plus 500GB External USB...
I have a 500 GB Lacie mobile drive and when I connect it using a USB cord it won't be recognized on the computer, however when I connect it using either the 400 or 800 firewire it works. I am having the...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Aug 10, 2010 | Computers & Internet
My external won't mount, the light works but it won't mount to my power book G4. help!
I opened up the harddrive and noticed that the copper magnetic film strip right above the USB port entry was lifted from the metal. I pressed it down and plugged the drive back in and it worked.
you just have to unscrew the drive on the 4 front side and two small ones on the side using two different phillips. then make sure and register the Western Digital drive inside because it has a seprate warantee. my acomdata is already out of warantee but if the drive ever fails again, I can have it replaced by Western Digital until 2011.
Dec 25, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie (301065U) 500 GB USB 2.0 Hard Drive Logo
52 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
