Question about Whirlpool GR448LXPQ Electric Kitchen Range
How much does replacement burner cost? - Whirlpool GR448LXPQ Electric Kitchen Range
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 14, 2010
ONE DOUBLE BURNER ONLY WORKS ON HIGH NO MATTER WHERE I SET IT
Hello Miguel;
My name is Peter. I am a retired field service appliance technician.
There are two electrical components that will cause this problem. The most probable cause is the burner element. Each of your burner elements have a independent temperature sensor. The sensor controls the burner element temperature.
Substitution Part Number: 4453909 Cost: $85.00
This surface element (part number 4453909) is for electric ranges, including Whirlpool electric range model GJC3034RB00.
Unplug the range or shut off the house circuit breakers to disconnect electrical power to the range before replacing the surface element. Wear gloves to protect your hands when replacing surface element on your electric range.
This is a manufacturer substitution. Part may differ in appearance but is a functional equivalent to priorparts including 9759351.
OR:
PART NUMBER: 8523698 Cost: $71.00
The other less likely electrical component is Surface Element Control Switch. Each burner has a independent control switch.
Cost: $46.00
To check the switch: Remove the switch 2 contacts on the left. With a multi-meter, set the meter to the lowest Ohms (Omega Symbol). Put one meter lead on one switch contact and the other meter lead on the other contact. If the switch is good you meter will read "0" Ohms.
Jan 18, 2015 | Whirlpool GR673LXSS - Stainless Steel...
Kitchenaid kerc507 burner indicator light stays on even when turned off
That is a common problem on these. To fix it you would need to replace the burner. Folks usually wait till the burner dies since they cost so much.
Nov 30, 2010 | KitchenAid KERC507 Electric Kitchen Range
Will not burn
It may cost up to $50 to trouble-shoot your CD-drive.
It will cost under $40 to purchase a replacement CD/DVD reader/writer drive.
So, your money, and your choice.
Nov 12, 2010 | Dell (0R649) CD-RW Burner
My DVD burner doesn't respond at all
Hi! I believe that the dvd burner is faulty. You will need to replace this for it may be worn for long time use. Hope this helps and have a good one!
May 29, 2010 | LG GSA-H55N DVD-RAM Burner
My cd burner will not burn cd's. it just makes a funny sound and pops up insert disc.
If the system is not in warantee, you will need to replace the CD burner drive. You can generally find a replacement for around $30. Depending on where you live you can find one locally or online.
Replacement is very easy.
Open the system to access the old CD burner, make sure you take note of where the cables (power and interface cable). Remove the old CD burner and replace it with the new CD burner replacing the power and interface cable.
If I were you, I would op for a CD/DVD burner so that you can read and write both CD;s and DVD's. Cost should be around $40.
Jul 14, 2009 | E-Machines emachines (emachinees) CD-ROM...
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
Kenmore Burner Hissing Noise?
You are on the right track. Check if you can clean the burner. It may help. If you do have to replace the burner, get the stainless steel replacement. It costs a little more, but it lasts 10x longer than the steel burner assembly.
Apr 26, 2009 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Having trouble with dvd burner
Usually when this occurs at our shop we just replace the burner. The cost of repairing these is typically more than just replacing them :-(
Sep 14, 2007 | LG GMA-4020B Super-Multi...
Whirlpool GR448LXPQ Electric Kitchen Range Logo
85 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
