Question about Samsung Microwave Ovens
I have a 2 year old samsung RSH1NHSW side by side refridgerator (without water cooler). The fridge side will not cool below 12 degrees. The light works and it sounds as if the pump etc are still going but it is not registering less than 12 on the outside panel. I can programm it to go lower but it is not getting colder. It would seem thet the cooling system on the fridge side is broken. The freezer side is fine. I have tried turning it off and leaving it for half an hour then turning it back on. No success. Is there anything else I could try. We like this device and do not really want a new one, especially as it is only 2 years old.
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Hello check out this youtube channel on samsung fridgefreezer
this video may alsl help ...
Posted on Sep 19, 2010
My freezer is draining water into the refridgerator. how do I fix this. The back of the entire unit is covered.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 24, 2011 | Microwave Ovens
I need to change the water filter in my samsung srs618dp fridge freezer. I have the filter but cannot locate the internal part in the fridge i need to change.
For Samsung side-by-side refrigerators, there are two possible locations. One is in the upper right hand corner of the refrigerator. The other is behind the veggie drawer.
To access the filter, either remove the top glass shelf or the vegetable bin. Turn off the water to the refrigerator. If no filter is currently in use, remove the cap. If a filter is in use, remove the old filter. Turn clockwise to remove the old filter. Save the cap to reinstall if the fridge is ever used without the filter. Note the date when you put in the new filter and place the sticker on the filter. Remove the red cap from the new filter and align the unlock mark with the filter mark on the filter housing in the refrigerator. (Looks like an unlocked padlock with the u part turned 180 degrees from the rest of the lock). Turn the new filter counter-clockwise 90 degrees until the lock symbol (closed padlock) lines up with the mark on the housing. Use steady firm pressure - it will be hard to turn. This ensures a tight seal. Turn on the water line and check for leaks. If the filter isn't leaking replace the shelf or the vegetable drawer.
Samsung support for the SRS618dp is here: http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=2201&prd_mdl_cd=RS23DENS1%2FRAD&prd_mdl_name=SRS618DP&srchword=SRS618DP .
I hope this helps.
Jun 12, 2011 | Microwave Ovens
Have water dripping into refridgerator from cold air vents
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
May 07, 2011 | Microwave Ovens
Hi at the back of my fridge freezer i think the compressor at the bottom is very hot, also the small pipes at the back is not heating as much as the compressor, actually anything but hot but not cold...
It possibly needs re gassing. Call a refridgeration expert in to look at it for you, there is nothing you can do without the gas bottles and evacuator.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
My freezer is working fine but the fridge is not cooling. It is a kenmore side by side 26 inch and is 9 years old.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 24, 2010 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
The fridge I have is only 4 years old but continually freezing items. eg 2litres of milk overnight!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Microwave Ovens
Freezer is frozen, refrig is 60 degrees? Cause? Convection fan?
heatman101
Sep 03, 2010 | Microwave Ovens
Microwave Ovens Logo
317 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
