Question about Whirlpool Refrigerators
Water supply in door of side-by-side unit does not shut off
  • 2,841 Answers
The solenoid that shuts the water on and off is defective and needs replacing. Located on the back of the unit where the water line enters the frig.
Posted on Sep 13, 2010
Kenmore elite refrigerator water stopped dispensing from door
HI.CHECK WATER SUPPLY FIRST.then defrost fridge.if this basic fails u need to check 1-supply to valve 2-the valve itself 3-pipes 4 -microswitch.good luck ali
Jul 04, 2012 | Kenmore Side by Side Refrigerator
I have replaced the water filter inside the unit but not it will not despence water.
It is very common on these units for the water line to freeze inside the freezer door. They did not insulate the door well enough. there was actually a recall on many models where they actually replaced the entire door under warranty. To determine this you need to remove the bottom kick panel and there will be a quick disconnect at the bottom of the freezer door. (to remove you need to kind of push the line in and then pull back out) Once this is disconnected close the freezer door and try to call for water. If you get water coming through the line to this point then you know its frozen inside the door. The only fix for this is to shut the unit down for 24 hrs with the door open to let the line thaw back out. If you dont have water to this point you will need to look at your saddle valve where the water line is tapped into your main line. It may be clogged up with calcium deposits. If you have an icemaker and its making full sized cubes this will most likely mean the issue is not with your water supply. Also if your dispenser has a little switch that slides back and forth to go from crushed/cubed/water it is common for these switches to go bad. Hope this helps let me know what you find.
_MJ_
Dec 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water continually drips from the freezer door water dispenser. it will stop if I shut off the water supply.Refrigerator is a 12 yr. old GE side by side
The lever you push for water does nothing mechanically to open any water valve. All it does is activate a solenoid coil on the water valve. The water valve itself is dripping like a faucet and needs to be replaced. To replace the valve shut off the water supply and disconnect the water line from the valve. Install the new one. Nothing to it.
Apr 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile refrigerator side by side, water and ice through door. Ice maker works fine, water will not shut off. Had to turn water to frig off.
The water inlet valve on the back where the water supply connects to the unit is stuck open. You may can clean the valve out and get it to closing or just replace it.
Dec 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water Filter
If you have a GSH25JFRx.. (x = E,F,G,H,I, or J) it will use a MWF (formerly GWF) water filter. It is a can shaped filter located at the top right back of the fresh food section. Give is a quarter turn CCW to remove. (the water auto shuts off when you remove the filter)
Apr 28, 2009 | GE GSH25JFR Side by Side Refrigerator
Water Dispensor leaking - HELP
shut off for the water supply igenrelly under the kitchen sink or in the basemant. no need to shut off main water supply to home. only to the unit itself
Oct 27, 2008 | KitchenAid KSCS25FKSS Side by Side...
Machine came up with E91 and then powered down
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Feb 19, 2008 | AEG Lavamat 72640 Front Load Washer
Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Feb 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice door won't open
Wow, what I job "i know". Even though its a new door it is possible for the sitch(#13) to be burned out. Also look at diagram. you may have bumped something loose! goodluck dd7d24c.jpg
Dec 16, 2007 | Maytag MZD2766GES Side by Side...
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
