Question about Peg Perego John Deere Gator HPX Ride on Toy
We just picked one up used> it wont "stay in reverse" are you supposed to hold down the gear shift while reversing? Also, how long should it charge for?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Yes you have to hold down the shifter to go in reverse, 1 hour for every ah that the battery is, so if its a 12ah battery then charge it for 12 hours
Posted on Jun 13, 2012
3 Suggested Answers
  • 19 Answers
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: no forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Posted on Jul 08, 2010
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
My T45 transmission is stuck in first gear and bogs down when I shift it to reverse
It appears this is a 5 speed manual transmission. There may be shift linkage problems between the shift lever and transmission. also bushings. I strongly recommend a repair manual specificly for this transmission. possibly filespeep.com or manualslib.com
How is the clutch and throwout bearing?
Mar 22, 2015 | Cars & Trucks
2000 jetta manual gear shift will not engage into reverse
Hi. Please check if there is something in under the gear lever in the centre consol, eg a coin. If not then i would look at the linkages under the car.
Jan 12, 2014 | 2001 Volkswagen Beetle
1994 dodge ram 1500 2wd wont shift out of 1st gear.reverse works
take bottom pan off clean out your pressure sensor .. tends to get mini metl flakes caught up in there wich is also a bad sign that your tranny is going out but this will buy you atleast another 2 to 3 months
Apr 14, 2013 | 1997 Dodge Ram 1500 Club Cab
Dash shift lite idcaters out on my 2001 mitsubishi eclipse gt spyder
For Automatic transmission problem,click the link below:---- Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 19, 2012 | 2001 Mitsubishi Eclipse Spyder
Grinding when in reverse and tries bogging down at lights
stop shifting so hard. your reverse gear is the same exact gear as your first, so if you shift hard and grind that gear a little then reverse will be harder to get into. you probably need your transmission rebuilt the harder your engine has to work the more its going to bogg down
May 14, 2009 | 1987 Ford Ranger
ATV Polaris 330 (I think trailblazer) wont shift into gears
I have one of these and it always throws my friends for a loop. You have to push the foot brake to get the bike in park or high. It should shift very easy with the brake down, if not check if the spring didn't come off of your brake pedal. I hope this helped.
Apr 04, 2009 | Polaris ATV
Reverse gear
You have to hold the lever on the gear shifter up then go all the way to the right and straight back.
Oct 07, 2008 | 2004 Hyundai Tiburon
Peg Perego John Deere Gator HPX Ride on Toy Logo
91 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
