I have had this aficio 2022 for less than 2 years and have less than 20,000 copies. I only have used it as a copy machine . There is no network card , or ethernet port , but there is a printer parallel port . I now want to use it as a printer so I connected it to a computer , downloaded the drivers , and the computer says the printer is installed fine . The problem is that it will not print , if I unhook the parallel cable the computer doesn't sense that anything has changed , its as if the parallel port doesn't work . I took of the back of the copier to see if maybe it was a dummy port that led nowhere , alas it is wired to the board. Below where the port connects to the board there is a red blinking light above a small switch with 4 tiny switches , what is wrong with my parallel port ,
I've got a Rico Aficio 2035
1.) It does have a hard drive installed (doc server)
2.) There is not a memory card installed
3.) There are no pinter buttons on the control panel
The rest of the scenario is the same...IE1284 Parallel port, but does nothing...
We have ours on the network, and it is set up to forward all incoming faxes to an email address...
(More)
We have ours on the network, and it is set up to forward all incoming faxes to an email address instead of printing. It was working fine, then it started printing faxes, and on the Communication Failure Report, it is saying the error is #1 Hang up or line fail. The email account is good and is reciving emails just fine. How can we fix this.
I Cannot install Ricoh 2022 with snow leopard. I tried to use the drivers I found in...
(More)
I Cannot install Ricoh 2022 with snow leopard. I tried to use the drivers I found in www.ricoh-support.com but they are for leopard (10.5) and they don't work. I also used the drivers I found from apple (ricoh 2022 gutenprint v.5.2.3) but nothing again. The printer seems to be installed but when I try to print something it doesn't go to the printer (usually it stops at 59% in the quew). The IP adress is right and checked and the printer is on. Do you have any idea? Thanks
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check...
(More)
Everything I print from my Brother HL-5240 printer comes out with both sides of the paper/check curled up.
