Question about LG Panorama 20.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
The ice maker isn't working and I can not open the door to the ice maker...HELP model # LFX25980ST
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hgdjdhg
Posted on Sep 30, 2010
Why is my LG LFX25980ST is not cooling any more?
Hi John,
are all the lights on??
if yes, check for fan fuctionality and ice build up inside the freezer portion if freezer is warm, then either the compressor electronics or your cold control could be bad. Also the LG fridges have some issues with coil leaking.
so first look at that and if is warm try to check if the compressor works.
hope this helps!
Jun 03, 2014 | LG Lfx25980st French Door Refrigerator...
Where can I get a replacement solenoid switch for my LG LFX25980ST?
Hi Bob,
this is the part number #6421JB2002L you can get it easily online in various sites like sears, appliancepartspros, etc.
hope this helps.
May 30, 2014 | LG Lfx25980st French Door Refrigerator...
What's your problem?ice maker isn't working
Assuming the coils underneath the ice box are clean and the ice box freezer section is running under normal operating conditions so that the ice mold thermostat can close contacts @25F, their are 2 suspects. The ice maker itself and the ice maker's water supply valve. Most of these supply valves have 2 solenoids for ice maker and water through the door. If the water valve is ok then the ice maker is bad.
Sep 27, 2011 | Kenmore Side by Side Refrigerator
My ice maker does not work. How do I remove it to check it?
Hi and welcome to FixYa, I am Kelly.
There are at least 3 different ice makers in use. They are not all the same. What is your make and model number so we can cite applicable reference material to help you?
This is just a guess.... at matching a manual to your unit, but download this manual and follow the troubleshooting procedures:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note.. Trouble shooting is best performed while the ice maker is "Installed"
If the ice maker checks out ok then most likely the freezer may not be getting cool enough from either a automatic defrosting problem or... an evaporator fan motor that is not running at full speed.
Additionally... if the freezer door switch has failed the ice maker will not work at all even if you are following the steps in the manual link above. The door switch controls power to the ice maker and shuts off ice maker power when the freezer door is open. Most of the time you never realize the door switch has failed unless you manually test it with the door open. (i.e light on / off and ice maker power on / off as tested with a meter)
Thanks for choosing FixYa,
Kelly
Nov 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
LG Panorama 20.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
269 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
