Question about Campbell Hausfeld Air Tools & Compressors
My unit is the 2gal. fp204800 it comes on but no pressure at all
This just happened to me... I took the piston apart, and it showed that it went bad- (broke w/ sizure marks) ... This is why it doesnt pump air... Part to replace is the whole assembly... FP204825AV $42.26 best price I found online.. Dunno how much it was new- but now this should b good for another 7 yrs. Good luck-
Posted on Sep 21, 2010
Pressure cooker will not come on
junk it and get a new unit
have the wife read the user instructions that will come with the new unit
Aug 20, 2016 | Pressure Cooker Home
My D55141 heavy duty 2gal (7.6L) 150 psi max builds pressure up to around 150 releases pop off valve then keeps running, what causes this problem?
The pressure switch is either out of adjustment or has failed. The compressor should shut off at a much lower pressure than the safety valve (~100 psi)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Air Tools & Compressors
My craft..1.5hp 2gal only 20 lb of pressure and want stop running. Help me!!
is it blowing air through pressure reliefe valve or just not building air , check that pump oil is full.
Sep 27, 2014 | Cars & Trucks
What is causing my Hyundai 2050 air compressor not to build up air pressure when it is running
If the drive motor is running and you haven't got leaks then it is the compressor itself or the connection to it which is faulty. If the motor is working it doesn't mean the piston in the compressor is going up and down. There are various valves within the compressor that can either break or jam open and these can prevent a pressure build up.
I think this is one of those problems you need to have in front of you as there could be many failure reasons, some not good and others fairly easy to get resolved.
You need to strip the compressor down to find the fault and then assess if it is a repair or new compressor.
May 02, 2014 | Hyundai 2gal Air Compressor Kit - Hpc2050
Dewalt emglow 2gal compressor will not reach cut out pressure
This usually means you have a problem with the piston & cylinder assembly or with the valve plate. If the piston ring or cylinder is damaged, it will compress some air but as the tank pressure rises more and more air will leak past the piston. If the reed valves on the valve plate are bent, warped or broken the same will happen. It's easy to check them for damage by removing the head but Emglow parts are getting harder and harder to find.
Apr 26, 2012 | Air Tools & Compressors
Valve problems,
dont bother trying to fix it when they go wrong they go WRONG it is not worth the hassel Buy new one
Jul 21, 2010 | H.D. Hudson 96302e 2gal Stl Sprayer 1 Ea...
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
Unit will not come on at all has voltage to unit and to contactor?
Sounds like you lost the refrigerant charge. Low pressure switch will not let compressor run. Look for oil around the condenser tubes. If you find it, this is probably the leak source.
Jun 01, 2009 | Heating & Cooling
P-tac unit shutting off
Start the unit and check unit data ( suction pressure, discharge pressure, current reading voltage reading, check if no icing at compressor suction pipe and evaporator coil) if everything is normal. check the fallowing.
- check for out of range pressure switches. By pass pressure switches and start the unit if the unit continue to run check which of the pressure switch is open while the unit is running.
- check for defective timer and magnetic contactor or control rely.
- if the unit installed with freeze up sensor then check it also.
- Or the control by itself.
Nov 09, 2007 | Kenwood KW85 Air Conditioner
Air Tools & Compressors Logo
244 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
