Question about Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty
While trying to start gas pourred out of the exhaust
    President:
  • Craftsman Master
  • 1,545 Answers
The needle valve in the carb evidently is not seating and allowing way too much fuel to continually enter into the fuel system. Remove the carbs float bowl to check for this. Float pushed up...should be no gas flow...float hanging down..gas should flow. The needle valve is probably either sticking open or debris in the seating area is not allowing it to seat (which shuts off the gas flow).
Posted on Sep 13, 2010
94 lexus es 300 leaking gas and white smoke from exhaust tail pipe and when I turn off the car it starts to pour out of the same spot
Charles, after searching the net., stuck injectors,faulty fuel pressure regulator or faulty ECU. Have a good Tech, check engine codes, diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
White smoke out of exhaust not what you think Club Lexus Forums
Es300 Smoking Bad And Gas Smell Help
http://www.automotiveforums.com/t967184-_93_lexus_es300_fuel_in_exhaust_runs_rough.html
Jul 09, 2016 | Lexus Cars & Trucks
Why does my craftsman riding lawnmower have gas coming from the exhaust?
Needle valve in the carb or problem with the float. Take the carb bowl off and look.
Jul 13, 2014 | Craftsman Garden
Spitting sputtering
These things are notorious for having crank sensor failures. Not too expensive and not too dificult to replace. I would try that first.
Jan 14, 2014 | Ford Explorer Cars & Trucks
1997 polaris trail blazer 250 fuel pouring out of exhaust
Your needle and seat is stuck open.Youll have to open up the carb.
I have changed lots of these. I worked for polaris for nine years.
Jun 06, 2012 | Polaris ATV
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
When i try to start my 03-250 ninja gas pours out of the exhaust
you need a carb clean. your float needle valve assambly is not functioning properly. could be something preventing the float needle from closing all the way.
May 10, 2010 | 2008 kawasaki Ninja 250R
1991 toyota 3L V6 Overfueling, raw fuel pouring out exhaust pipes
The valve cover gasket change is related only to the extent of needeing to remove something else . There is the fuel pressure regulator and the MAF SENSOR talks to the ECU telling the computer how much fuel is needed for proper mixture of thre air passing into the intake. It is the first sensor in the intake duct coming out of the sir filter. Make sure all the injectors are secure in wiring connection and look around for any other that had to be removed. All plugs mean it isn't just one injector. Unplug and replug the MAF. cHECK THE THROTTLE POSITIO SENSOT. iT RIGHT THERE where the fuel likage is attached.
Jun 02, 2009 | 1994 Toyota Pickup
Not getting gas to combustion chamber, leaking gas from exhaust
Definitely the carburetor. Take it off and look for something clogged. Look carefully at the gaskets. Look for water and dirt in the float bowl.
Nov 23, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Will not start unless i pour gas into the carb
Adjust the valves .006 intake, .010 exhaust
Aug 19, 2008 | 1987 Isuzu Trooper
Craftsman 21 Hp 42" Lawn Tractor Riding Mower Warranty Logo
182 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
