Question about D-Link Air DP-311P Print Server
Hello, we have a D-Link DP-311P Wireless and have had it for several years - we can not remember the password - is there some way that we can reset it....help please
  • 131 Answers
The default password is SYSxxxx, where the xxxx is equal to the final 4 digits of the MAC Address
The default password could also be SYSADMIN.
If neither works, then the print server will have to be sent to D-Link to be reset. Please contact D-Link's RMA department at 800-326-1688 M-F 7AM - 6pm Pacific time about how to send it to them.
Posted on Sep 16, 2010
Can not remember the password for wireless router
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 16, 2011 | D-Link DP 300U (DP-300U) Print Server
My home network uses WPA security. How can I use my D-Link DP-311P print server? It seems to support WEP but not WPA.
This is a very old 802.11b only print server (made in 2003, discontinued in 2006), and only supports WEP It also runs the slower 802.11b protocol (11mbps) and will tend to slow down your whole wireless network if you use it. You are much better off replacing it with a more modern print server.
If you insist on using it, you will have to switch your wireless network to use WEP instead of WPA.
Apr 12, 2011 | D-Link Air DP-311P Print Server
Hello. I have a new Windows 7 machine and cannot figure out how to connect the dp-311p print server to it. The old directions for Windows XP don't seem to work. Help, please?
The wireless printer is somewhere on your "local network".
Access "Control Panel", and access "Printers".
Click "Add Networked Printer", and "browse" your local network to locate the print-server.
Tell us any error-messages that you get, if any.
Feb 05, 2011 | D-Link Air DP-311P Print Server
Cannot access the DP- 311P Settings page using browser and http://192.168.0.10, using XP Pro, Firefox or IE8, Epson Al-C900 printer. DP -311p is plugged into the parallel port, wireless cofiguration set to...
Have you plugged this into your computer with an ethernet cable, you need to use a cable when you set it up, after you have completed the setup, you should be able to connect through the browser wirelessly
Aug 01, 2010 | D-Link Air DP-311P Print Server
Is it possible to get a DP-311P print server to work with an Epson AL-C900 laser printer?
It should if your printer has parallel port in the back. Follow the instructions manual, connect print server to the parallel port and then to the network. Get the manual here:
http://www.dlink.com/products/default.aspx?pid=DP-311P&tab=3
Click on support resources and choose our country. Go from there
Does this DP-311P print serverwork with a wireless
I ready all about your device here:
http://www.dlink.com/products/?pid=DP-311P
And I do not show that 802.1.5.1 which is Bluetooth. They do have a small section but it just states the range of Bluetooth.
The best way to do it, turn on your laptop/device and have it start searching. If it does not show up on the list, then more than likely it does not support it.
Have a great day.
Jan 21, 2010 | D-Link Air DP-311P Print Server
How do you connect to the DP-311P to reset it when you don't know the proper IP address you can't open its engine even when the wireless is connected
Hi you can Verify IP address and port information on the print server by using either telnet or PSAdmin.however you can try using the the default IP address is 192.168.0.10. Let know if it helps?
Apr 09, 2009 | D-Link Air DP-311P Print Server
DP-G301
Update the firmware of your Print Server.
Mar 04, 2009 | D-Link AirPlus G DP-G301 (DPG301) Print...
D-Link DP-311P Wireless print server reseting
Hi Luis,
Sorry, it had been my mistake, did not realise your model does not have ethernet port at the back.
On D-Link printer servers that do not have cable connections it requires a couple more operations, you must do the following to connect safely to the server and open configuration:
  • On the rear panel of the DP-311P you fiind a switch to set server to Config mode. Set the switch to
  • Now go to the computer that is connecting wirelessly to the D-Link, go to wireless adapter properties, for example using control panel, and set the adapter to Ad-Hoc mode.
  • Change manually the wireless adapter IP Address so that it is in the same IP Address range
  • as the DP-311P, set the wireless adapter to a static IP address comprised within 192.168.0.2 and 192.168.0.255 excluding 192.160.0.10.
  • Always in wireless adapter settings >> IP configuration, set subnet mask to 255.255.255.0.
  • Ensure you click OK, or Apply in network settings Window, and restart the computer to apply new network settings.
  • Open Internet Explorer and type the IP Address of your wireless print server in the address bar. The default IP Address is 192.168.0.10.
You also find procedure explained at page 7 of the user manual here : D-Link DP-311P
Then follow instructions at page 15 to reset the server.
After you have finished configuring the DP-311P, to save the changes, you must toggle the mode switch on the rear panel of the print server back to “Normal” mode.
Oct 25, 2008 | Office Equipment & Supplies
How can I reset the print server configuration????
Connect a computer to the DLink using a cable. Put 192.168.0.10 in the web browser (internet explorer) and follow instructions at page 15 of the user manual here ( http://ftp.dlink.ru/pub/Printserver/DP-311P/Description/DP311P_manual_100.pdf )
Oct 22, 2008 | D-Link Air DP-311P Print Server
D-Link Air DP-311P Print Server Logo
231 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
