Question about Mitsubishi HS-U770 S-VHS VCR
My Mitsubishi HS-U770 won't keep the VHS tape in - keeps spitting it out. I did some research and it seems a belt might be slipping which keeps it from loading completely. What can I do?
  • marcia777 Sep 13, 2010
    Thanks for the tips. I have been fond of this particular model for digitizing VHS tapes to Final Cut Pro. Guess I have to bite the bullet and find another reliable model. If you have a recommendation, I'm open. Thanks for your speedy response.
    Yes, and I appreciated the expeditious nature of the response, along with the level of expertise.
  • 1,606 Answers
The belt is real easy to replace. Should cost about $4 at most. The problem is finding the right one. The belts stretch out with use so if you take the belt in you need to get one that is smaller or you just end up with a new belt that slips.
The hardest part about this is finding a place that has the belts. Usually you can call around town to any electronics store and one will be able to tell you where there is a source and maybe a repair person. I haven't done one of these for quite a while but the usual fee was about $75. The problem is that you can buy a cheap vcr for way under that so no one fixes them any more. So you may end up just replacing it, even though there is nothing really wrong with it.
Posted on Sep 13, 2010
  • Dave King
    Dave King Sep 13, 2010
    I haven't kept up with what is available so I can't really help you with that. I finally tossed out a 4 head jvc I kept running for years (paid $1400 for it) The reason I kept it was that it still had better imaging than the newer stuff. So what I would consider is repairing the Mits.I keep seeing cheap vcrs for $30-$40 but I doubt they last more than a few minutes longer than the warranty. The newer stuff uses a lot more plastic and it shows on things like gears. The plastic gears will get brittle over time and the teeth chip or the alignment goes out. The older quality machines keep on chugging away if you feed them a belt and clean the heads from time to time.
    You could try a cheaper one to use while you hunt down the repair shop to get the mits fixed.
Need price
It was about US$850 maximum new in 1994, worth nothing now to sell.
Jan 27, 2014 | Mitsubishi HS-U770 S-VHS VCR
Price to buy a new one
I would contact Mitsubishi as they should know! Just explain to them why and ask for the recommended retail price.
HS-U510(c) Recently the tape is not rewinding. When ejecting, tape not rewound from heads and gets caught in mechanism. Defenitely seems to be some rewinding problem as noise of gears grinding and...
The problem is in the idler assembly that runs the tape and reels it in on eject, the drive belt will probably need replacing that is attached to the assembly.
Mar 27, 2011 | Mitsubishi HS-U510 VHS VCR
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
Tape stuck will not eject
open vcr look for a belt on the right side of the vcr and begin manually turning it until the tape ejects
Jan 04, 2010 | Mitsubishi HS-U770 S-VHS VCR
When I put a tape in my vcr it spits it back out...
this sounds like a cleaning and tape carriage alignment is needed, that not too hard to do if you tinker.Service on this is not too much at electronic or tv repair
Jan 26, 2009 | Mitsubishi HS-U545 VHS VCR
Plays for 3 secs, stops, and then ejects
This unit needs to have the "idler" changed as well as the belts. Over time, the internal rubber parts get hard ans slippery. There are safety checks inside that will stop the unit when problems are detected. With a slipppery idler assembly, the tape does not get wound into the cassette after passing the heads. Rather than have the tape collect inside and be destroyed, the unit stops. This is a relatively simple repair that any shop should be able to perform. Expect a parts cost in the $35 range. In my opinion, this unit is worth the repair as it will continue to provide service to you for years to come. New replacement units tend to last only a year or two.
Dan
Dec 30, 2008 | Mitsubishi HS-U770 S-VHS VCR
Replacement Belts for Mitsubishi HS-U560
You can try Vancebaldwin.com or MCM electronics corps, or even tritronics INC.
Mar 22, 2008 | Mitsubishi HS-U560 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Televison & Video Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
