Question about Acer TravelMate 2300 Notebook
Startup problem when pressed power boottn the led are blink for few second only. the laptop acer travelmate 2312nlci doesnot start or no responding. please help me.
  • Anonymous May 27, 2008
    The dc jack pin is broken. not getting power.The little bit you see is the last little bit of life in the battery.Or your power pack is out. if not the power pack its most likely th dc jack. You will have to solder a new one on the power board.
    Problem Solver:
  • 11 Answers
  1. do any of the fans come on when you hit the power button?
Posted on May 15, 2008
Acer Travelmate 6592G Wont Startup
do the HARD reset. Disconnect the power adapter +battery. Hold the power button by 30 seconds. And then reinstall the power adapter and battery again and test again. this will solve the problem God bless you
Apr 04, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
Acer Travelmate 6493 not turning ON. It was working fine till i closed the lid and went away for some time. When came back and opened the lid it was not responding and Dead. Tried to reset by pulling...
unplug the power and remove battery.Then press power button to discharge any power left on capacitors.plugg only the power in leave the battery out and try to turn on the laaptop.
May 19, 2017 | Acer TravelMate 6493 Intel Core 2 Wireless...
I just want to know to turn on my TravelMate Laptop computer. I want to where the start button is? Simply as that.
You will find a key that has C facing upwards with an I in it. This is the power on switch.press it lightly. Three LEDs will turn green for a moment and then some more LEDs with start blinking. And finally you will get the Windows desk top.
Nov 08, 2009 | Acer TravelMate 4150LCi Notebook
Battery status LED blinkings amber
Try removing the power cable and battery, while these are removed press and hold the power button on the laptop for 30 seconds. this is called a hard reset, what it does is drains any residual power in the laptop. if this does not work, that means there is an issue with the motherboard. to have it sent in would cost about $398, give or take.
Jan 25, 2009 | Acer TravelMate 3260-4874 Notebook
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Donot startup
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Acer TravelMate 2300 Notebook
Can't start
Try removing the power adapter and battery. Then hold the power button in for up to 60 seconds to discharge the laptop.
Plug it back in and see if it will boot.
May 04, 2008 | Acer TravelMate 292ELMI Notebook
No working
Virus infected or some startup programs make conflict with another program
go start run msconfig and startup
Desable all programs just DO NOT desable antivirus and let me know if u got help
Nov 02, 2007 | Acer TravelMate 290 Notebook
Acer travelmate 292elcI problem starting
Hi, sorry to hear you are having problems. When this happens it usually suggests that the CPU/system board has failed. If the laptop is still under warranty I would suggest taking it back because this is something that will be covered and they should be able to fix it or replace the laptop itself. If not you may have to pay to have the system board/CPU replaced. Good luck and hope this helps. Si :)
Sep 26, 2007 | Acer TravelMate 292ELMI Notebook
Computers & Internet Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
