Question about ASUS P5PE-VM Motherboard
Asus p5pe-vm Can anybody can help me? i Have a mobo f asus p5pe-vm and my problem is this...i want to have a usb connector in the front panel but i dont know how to connect the jumper settings because in the manual the jumpers have a usb+5v,usb_p5-,usb_p5+ ang GND but in my casing i have a -D, +D,VCC and GND cn anyone can help me to solve this or can anyone can give me the color of the jumper to connect usb 2 to the motherboard? thanks a lot!!!!!!
  • enigma pulp May 16, 2008
    tnx pal i will do it soon..
  • 472 Answers
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
"GND" = GND
Posted on May 15, 2008
Trying to find sound chip so i can restore my sound on my computer. i loaded windows 7 professional and i have an intel asus p5pe-vm mother board. need help please
This is just simple way. Just connect your front panel audio plug connector with your mother board audio socket.
In your motherboard there are several chassis-mounted functions. For your help i add a motherboard layout image.
Jul 03, 2016 | ASUS P5pe-vm Motherboard Intel 865g Lga...
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
How do I install the font usb to a ASUS P5PE-VM motherboard?
see mannual and find front panel usb connector on mainboard insert usb connector in it..
Apr 01, 2010 | ASUS P5PE-VM Motherboard
What mobo can replace ASUS P5PE-VM
the socket of you processor is lga775, the graphics port is agp and it support DDR I , so you need to buy a motherboard that has the exact specifications.
my advice is to continue with asus. you could buy an Asus P5P800/ P5S800 that is compatible with your previous motherboard. there are also some good models from asrock and they may be cheaper than asus.
the problem with this type of motherboard is that they are expensive because that are not in use.
Dec 20, 2009 | ASUS P5PE-VM Motherboard
Asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
Look this picture below, this is ASUS P4VM front panel.
Hpe its solve your problem....
Nov 26, 2008 | ASUS P4S533 Motherboard
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Front audio in casing
The front panel audio for this board is labelled FP_AUDIO and is on the bottom left hand side of the board. See page 39 of the following; http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf They're all labelled correctly. In your case, L-out - Mic2_L, L-ret - Mic2_R etc
May 29, 2008 | ASUS P5PE-VM Motherboard
F_AUDIO <==> CASE
1- PORT_1L == MIC_IN
3- PORT_1R == MIC_PWR
5- PORT_2R == R_OUT
9- PORT_2L == L_OUT
-------------- OTHER SIDE ------------- (case wire)
2- GND
4- GND (other)
6- R_Return
8- key
10- L_Return
May 16, 2008 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
327 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
