Question about Hitachi 53SWX01W 53" Rear Projection Television
3 WAVY LINES RED,GREEN, AND YELLOW HOW TO FIX IT
  • Hitachi Master
  • 8,457 Answers
Ur tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis aliignment,have colors shadows or 3D pictures.The tv convergence board,must require 2 STK convergence ICS and some or all it resistors to replaced,to solved the tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Sep 13, 2010
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Red and green wavy lines
chek your power in if it is stabile than you musht range a power stabulisator othervice if is ok need chek in to change crystal diodes and aom other parts
Jan 22, 2010 | Toshiba Televison & Video
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
If the distortion that you see can be described as somewhat of a 3-D picture, the problem is teh convergence circuit and this can be fixed easily. Also, if you can solder, you can fix this yourself. If you wish to do this, please update this and I'll provide you with some instructions.
Dan
Sep 12, 2008 | Akai PT5492S 54" Rear Projection...
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
Sony Convergence
Jan 25, 2008 | Pioneer SD-643HD5 64" Rear Projection...
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 24, 2007 | Televison & Video
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Open Questions:
Blue Ray Compatible? I have had my Hitachi 53SWX01W set for maybe 7 years or so. It is HD ready. My DVD player that I had hooked up to Component jacks #1 crapped out recently and I was using a portable DVD player in the front jacks. Everything always played perfect. I bought a Sony Blue Ray player and a Samsung HD Tuner over Thanksgiving and installed them. HD Tuner on component jacks #1 and the Blue Ray on CJ #2. Both with sound through fiber optic. The tuner was a snap and the picture is great. The Blue Ray was also a snap and Blue Ray disc's play great. My problem is DVD's! When playing a Standard DVD the picture will blank out radomly for 1/2 to 3 secounds and it may do it once or twice per disc or it may happen randomly throughout the disc. Sometimes it will not happen at all and the next day playing the same disc the picture will start blinking out again. There is no interuption in the sound or place in the movie, just a loss of picture! I have traded component jacks between the tuner and Blue Ray, I have change Component cables from very expensive to very cheap and back with no noticable difference. I exchanged the Sony BDP-350 Blue Ray player for another player with no success. I still have the same problems. When veiwing Blue Ray disc's The TV will display 1080i resolution with no problems at all. When playing standard DVD's the TV displays 480p resolution and the blinking problem happens. The Blue Ray player dosen't ramp up the picture quality on DVD's as I thought it would but that could be because I'm not using an HMDI cable which my TV does not have. Please HELP!!! Jim
Dec 17, 2008 | Hitachi 53SWX01W 53" Rear Projection...
Hitachi 53SWX01W 53" Rear Projection Television Logo
174 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
