Question about Whirlpool Duet GHW9150P Front Load Washer
What is the code F 35 - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
Toshiba e-studio 35 erreur code 303232
That's not your error code, that's your meter.
Feb 02, 2013 | Toshiba e-Studio 35 Copier
Trouble code 35 chevrolet cruze
please advise what about the code 35 of chevrolet cruze 2010
Oct 14, 2012 | Chevrolet Cruze Cars & Trucks
What is the cause of code 35 for a 1993 impreza
that code is for a canister purge solenoid
Sep 03, 2012 | Subaru Cars & Trucks
Code 35
If you had idle problems or eratic idle with code 35 the IAC sensor may be bad or needs cleaning. Clear the codes and let me know if code 35 returns.
Oct 18, 2010 | 1995 GMC Yukon
My check engine is on and the codes that I get are 35 & 55 - what do these codes mean
code 35 is a problemin the cooling fan relay it is either open or shorted code 55 means end of code output,or to say there are no more codes. Ray
Nov 09, 2009 | 1995 Dodge Intrepid
Eurovox codes for 8th october
Oct 08, 2009- todays codes
CW Keys 5C01 updated 08/10/09 10:35
00= C5 BE AF 36 0A 61 91 AA
01= D2 D1 80 FA 21 85 0F 53
TW Keys 5A01 updated 08/10/09 10:35
00= 83 5D 12 B8 96 F6 1F C4
01= D2 F9 35 22 0C A7 D6 C9
NTL Keys 5401 updated 08/10/09 10:35
00= F0 0E 91 E0 2D C1 C5 FD
01= 5D 61 B2 C8 E7 DD F9 57
Oct 08, 2009 | StarTech.com StarView SV211K 2-port KVM...
TW Code Starview
New New codes for tw at 17.30 4/12/08
00=co f6 61 87 91 f9 67 57
01=83 35 e5 28 40 49 b2
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
Anyone got codes for 4th December??
4.12.08.
ntell
0=3F B8 36 62 72 E5 E2 76
1=35 5E D6 40 6E AA 99 41
tw
0=C0 F6 61 87 91 F9 67 57
1=F0 83 35 E5 28 40 49 B2
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
UNLOCK SAGEM MY W-8
imei unlock 332052-35-125357-0 3927257920 332052-35-129377-0 3362230830332016-35-146513-0 1558898480 332052-35-126828-0 4011806542332052-35-126963-0 0079539739 332049-35-321828-0 1503515261332052-35-126971-0 3852379919 332049-35-236282-0 1395096725332052-35-127534-0 0810548649 332049-35-176328-0 0947921989332052-35-128668-0 3830409997 332052-35-176099-0 0948020856332026-35-148914-0 0270060834 332052-35-174998-0 0445933997 Tout d'abord il faut rentrer dans le menu hotline3 du portable. - Pour ce faire, tapez *#06# afin de connaitre l'imei. - Enlevez les six premiers chiffres et le dernier. Il vous en reste donc huit qui doivent commencer par 35 ou 82. Procédez de préférence sur un tél sans carte sim. - Tapez * + les huits chiffres puis OK. Le menu hotline2 est activé. - Ensuite entrez dans le menu normal du tél puis tapez *. allez dans RAM, tapez l'adresse 112, validez, appuyez sur C, tapez 2 en nombre d'octets et validez. Apparait alors à l'écran : adr:112 puis 8967. Appuyez sur modifier ou C, tapez 7698 et validez. Voilà, le menu hotline3 est actif. Ce menu permet de lire et d'écrire dans tous les champs EEPROM (menu normal puis * puis 3, prom) sans câble. - Avant tout, allez dans le menu PROM, lecture/écriture, tapez 231 en champ et validez. Il y a 0 ou 00. Ce champ est le compteur de mauvais codes simlock tapés sur le gsm. Donc si vous en avez rentré le compteur doit être supérieur à 0! Mettez ce champ à 9 ou F s'il n'y a qu'un seul chiffre ou à 99 si y a deux chiffres. Ainsi le compteur est bloqué mais le temporisateur est désactivé, vous pouvez donc taper autant de simlock faux sans aucune incidence. - Maintenant allez dans PROM, tapez 0 en champ. Vous obtenez une série de lettres et chiffres que vous inscrivez soigneusement sur une feuille. Vous faites "annuler" et encore lecture/écriture mais cette fois çi avec le champ 251 et vous notez son contenu. Sortez du menu PROM pour allez dans RAM mais cette fois çi à l'adresse 219 avec 6 octets. Notez aussi le contenu. - Lancez le soft SAGEMSLCK, quand il vous demende de taper "I UNDERSTAND" vous le faites en majuscules obligatoirement. Il vous demande ensuite le choix "par câble" ou "manuel". Tapez "m" (en minuscules obligatoirement) manuel. Le soft demande ensuite de taper les contenus des trois champs eeprom et ram précedents et lorsque vous validez il vous donne le code simlock à dix chiffres.... Et votre phone est débloqué !!!Ca ne marche pas sur certains modeles. C'est peut etre dû a la version du soft qui est peut etre trop récente.Tenez moi au courant. Pour les Sagem 9500 et autres ??? des ptites indications au cas où les manips. seraient pas clairs :"il est difficile de deviner où il faut rentrer le code de deblocage une fois obtenu. Et c'est pas indiqué chez toi qu'il faut faire * apres Menu, etensuite qu'il faut rentrer dans la rubrique Sim lock."
Oct 24, 2007 | Lands Phones
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
