Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Friger too cold - GE Profile PSW26P Stainless Steel Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 27, 2010
My Freezer leaks into fridge, what can I do?
now if the refrigerator is leaking cold air from the freezer, that is normal, there should be a vent, or control handle near or inside the frigerator on the freezer side of the refigerator, you can open or close so you control how cold you want your food to be cold
Apr 22, 2015 | Refrigerators
True commercial frigerator shuts on an off
my guess is u may want to check the cold control thermostat
Mar 15, 2015 | True Refrigerators
My frigerator will not keep cold
possible freon leak
temperature adjustment component may need replacing
Possible compressor malfunctioning
Sep 13, 2012 | Frigidaire Refrigerators
Freezer works but frigerator does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 14, 2009 | Refrigerators
The frigerator and freezer are not getting cold enough.
It sounds as if your unit is low on freon.You will need to have a quailfied repair person to refill.
Jul 02, 2009 | Refrigerators
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Frigidaire Model FRT18L4JB1 frigerator not getting cold, the freezer is working fine.
check to see if freezer wall is full of ice if so you have a defrost problem timer,heater or limit switch
May 08, 2009 | Refrigerators
Frigerator is freezing.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
The fridge compartment doesnt keep food cool
The frigerator doesn't keep cool and I've even set it on the highest number which is nine, It's still not cool or cold. What's going on?
Aug 04, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
62 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
