Question about Health & Beauty
I have a 2006 Schwinn Motor Scooter "Collage". A few weeks ago I washed it and now the turn signals don't work. The turn signal lights come on but don't blink. However, the right turn signal light does not come on at all. Is it possible that the flasher went bad, does it even have a flasher and if so, where is it? What else could cause this problem? Where can I purchase an indepth repair/shop manual.
SOURCE: turn signals
replaced turn signal flashers and muti switch turn signal still won't work Why?
Posted on Nov 11, 2008
  • 298 Answers
SOURCE: 1987 Yamaha Riva XC200 turn signals
You need to replace the flasher relay on your bike. Its a black plastic cube or rectangular in shape that has the inscription Denso (usually) in it. It should also have the inscription "4 bulbs 25 watts".. this is the main unit you need to replace.
Posted on Mar 15, 2009
  • 187 Answers
SOURCE: 2006 Ford Escape - Right side flashers (turnsignals) not working
Check the wires at the connection point and follow them back up to the tail light look for any disconnected wires or grounds. Good luck.
Posted on May 14, 2009
  • 125 Answers
SOURCE: 1993 XLH turn signal issue
How about looking at ALL of the fuses? A blown fuse can create lots of "back circuits" which will confuse you when trying to diagnose an electrical problem.
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: 1997 dodge avenger turn signal probs and location
replace the turn signal switch it self, mine did the same thing with the left turn signal, put in fuse and it will continue to flash... went to junk yard pulled one out of a 97 avenger just like mine, swapped them out and now it works fine. looked to be like some corrosion... to repace: 3 screws under columb, 2 screws on side of signal switch (black plastic side). unplug and replace
Posted on Jun 26, 2009
Honda metropolitan 05 Met II blowing 15 amp fuse
Did the scooter start OK when you first started it after bringing it out of storage, or did you have to use the kick starter? Maybe the battery is faulty and is pulling a lot of power.
Check the charge rate with an ammeter (use a multimeter that can measure 20 Amps DC) and see if the current exceeds the 15A rating of the fuse. If it does, replace the battery.
Sep 27, 2014 | Cars & Trucks
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Jun 26, 2011 | 1999 Chevrolet Venture
I have the same problem on my 2003 element that was reported on a 2006 Element about two weeks ago. No solution posted. "left turn signal with headlights off will work but radio display & drive...
This is the multifunction control module. Whne you look at the fuse box, you are really looking at a computer ie... the multifunction cotrol module. Everything goes thru this, except the ECM.
Jan 31, 2011 | 2003 Honda Element
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Mobility Scooter - Golden Companion 1
Please make sure you FREEWHELL lever located at the rear is in drive mode, if you can push it, move the level.
Aug 03, 2008 | Transport Schwinn Rechargeable Portable ...
Schwinn s-400 scooter no motor activity.
I had same issue, bought a new controller. 40 bucks from the manufacturer. Works great.
Jul 20, 2008 | Transport Schwinn Rechargeable Portable ...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
