Question about Whirlpool Upright Freezer EV161NZRQ
Food coming out of freezer covered in ice overfreezing
    Master:
    Sergeant:
  • 449 Answers
Have your themostastic control replaced (stop wasting money)
Posted on Sep 14, 2010
Freezer Constantly Runs.
Do you know what design temperature is for that freezer? Some are meant for 0 degrees others for -10 or 15. I would say you are trying to maintain -10 for a food freezer and trying to keep ice cream frozen. Ice cream freezers need to be colder than food freezers. I know it sounds dumb but look it up. Check the door gaskets to see that there is no leakage and the surrounding area should be no higher than 75 degrees, (otherwise it\'ll run all the time). Hope this helps and good luck.
Apr 20, 2014 | True 72 cu. ft. Commercial Freezer TS-72FG...
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
Not cooling, but fan inside running
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Apr 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer motor is not running. the ice in the freezer is melted
If you are referring to the evaporator fan motor located inside the freezer, if it is not running, then your symptoms would be cold food at the bottom of both sections, assuming its a side by side, and warm food at the top, both sides, also the icemaker wont make ice, and water likely wont come out the door. Depending on your brand, it could be the motor itself has burnt out, or possibly a bimetal thermostat, a cal rod heater, or an electronic control board.
www.FixMyFridge.net
Mar 08, 2010 | Freezers
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Sub-Zero 550 Freezer not cold enough
Start with the simple items first like checking the coils at the back of the freezer for ice. If there is let it melt away by unplugging the unit. Have the unity cleaned at that area whether there is ice or none and the entir fridge including the drains on the freezer. Then start the unit again.
Aug 31, 2009 | Freezers
Mountain of ice in walk-in(floor), around the parts(ceiling)
No choice but to move your food to a secondary unit & defrost the walk-in. If you go chipping around your condenser you risk more damage. Hopefully you have seperate breakers for you walk-in vs other cold storage areas.
Apr 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Whirlpool Upright Freezer EV161NZRQ Logo
57 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
